Old 04-10-2021, 04:32 PM   #1
Jasper
Jasper's Avatar
Drives: 2023 GR86
Dipstick Inconsistency
Does anyone share the issue of having to re-read the dipstick more than 3 times in a row to get the correct measurement?
One side reads low, other side reads high.
Re-measure- low side reads higher, high side reads higher.
Re-measure- low side reads lower, high side reads lower.
I understand it's the way these motors are built but what is a fool-proof way to know you've filled up enough/haven't overfilled?
I know there are aftermarket dipsticks where they provide a button (air suction button to my knowledge) that allows the dipstick to read precisely each time- but I'm not trying to spend $75+ for a dipstick. There must be a way.
Jasper is offline   Reply With Quote
Old 04-10-2021, 04:37 PM   #2
Transport3r
Drives: -
One side of the dipstick always reads wrong (way high), ignore that one. The other side is a bit inconsistent but making the surface a bit rougher by sanding it made a pretty good difference in increasing the repeatability.
Transport3r is offline   Reply With Quote
The Following 2 Users Say Thank You to Transport3r For This Useful Post:
soundman98 (04-10-2021), Wally86 (04-13-2021)
Old 04-11-2021, 08:54 AM   #3
tomm.brz
Drives: brz 2017 hksv2
it s kinda important the ground your car is parked in, must be very flat and no pendency
Old 04-11-2021, 02:14 PM   #4
Jasper
Jasper's Avatar
Drives: 2023 GR86
Definitely took that into account with all my dipstick measurements.
Leveled parking still does not allow consistent readings in my case.
Not just on my current 86, but also the same in my old FRS.
Same thing happens in my friend's STI.
The Following User Says Thank You to Jasper For This Useful Post:
Old 04-11-2021, 02:17 PM   #5
Jasper
Jasper's Avatar
Drives: 2023 GR86
Sanding is a good idea. Do you typically allow it to sit before reading the measurement? Or do you do push in and pull out really quickly? I personally noticed if I bend the dipstick to have a curve (curved in position facing the car, curved out position facing me) it seems to be a little bit more consistent but still not 100% accurate.
Old 04-11-2021, 05:13 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
What if you over sand? Too much oil will stick to the dipstick giving a false reading..
The Following User Says Thank You to JD001 For This Useful Post:
Jasper (04-11-2021)
Old 04-11-2021, 07:08 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
there's so much oil that goes so many places and slowly drains back, if at all, i don't ever expect to get a real reading.
close is close.
Old 04-11-2021, 09:04 PM   #8
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
I mistook this for an astute political observation. My bad.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 2 Users Say Thank You to MuseChaser For This Useful Post:
bcj (04-12-2021), soundman98 (04-11-2021)
Old 04-11-2021, 11:03 PM   #9
Jasper
Jasper's Avatar
Drives: 2023 GR86
Well maybe it's f*cking worth it to just get the $80 accurate dipstick. Fml... haha
Old 04-13-2021, 07:23 AM   #10
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I just do what you do. Take multiple measurements and hope for the best lol.
I have noticed the "low side" (what i call the front which actually points to the back of the car) seems to be more reliable when adding oil so I trust that side more.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 04-13-2021, 09:39 AM   #11
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Worry about it when the dipstick comes out dry
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
soundman98 (04-13-2021), Wally86 (04-13-2021)
Old 04-13-2021, 11:17 AM   #12
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I never really had an issue. One side will be correct and the other will be way high. Only look at the lower side.
In general, you want enough oil in there that the high hole is filled with oil, which will only happen when the actual oil is at that level. The 'high' reading will just slosh oil up the one side of it and not fill that hole.
As far as consistent reading, I check mine weekly before autocross and it's dead on every time.
cmiovino is offline   Reply With Quote
dipstick, dipstick measurement, oil, oil level, oil measurement
BRZ oil dipstick level? indio22 Engine, Exhaust, Transmission 34 09-01-2020 07:54 PM
Dipstick leak ? Geex Issues | Warranty | Recalls / TSB 7 12-17-2019 03:43 AM
Oil level on dipstick... Da Brz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 11-21-2016 06:44 PM
Dipstick question Qwimby2 BRZ First-Gen (2012+) — General Topics 26 11-27-2015 12:59 PM
oil on dipstick but not on hole ZionsWrath Engine, Exhaust, Transmission 2 09-08-2014 07:46 PM
