Old 06-07-2023, 05:31 AM   #1
renzs1
Drives: toyota 86 gts 2016
Can replacing an turbo actuator cause oil leak do to "pressurization"?
Hey guys sorry if this is a dumb question but i have a custom turbo kit that uses a gt2871 but the actuator pressure rating is 14psi. Im wanting to run on low boost so i plan on replacing it with a turbosmart 5psi actuator, I asked the seller if i can replace it with TS but he said replacing it could cause an oil leak due to incorrect pressurization from the actuator?? Can someone explain this to me? Thanks in advance! Again sorry if this sound like a stupid question •_•
renzs1 is offline   Reply With Quote
Old 06-12-2023, 11:14 PM   #2
colinshark
Drives: Some RX-7s
That doesn't make any sense. I can't think of anything real they might be talking about.
Lower boost actuator is the way to go for low boost.
You could install it yourself when you get the kit in your hands. It might involve some minor fabrication for the rod or mounting.
colinshark is offline   Reply With Quote
Old 06-12-2023, 11:19 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
That tuner must specialize in WRXs. The oil sump on the WRX has issues when people remove the restrictions in the exhaust- you're going to be doing the opposite so I don't really understand where they're coming from.
It sounds like they just don't want to do it.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
FS: 2013 PTUNING Turbo Scion FRS "BABY LFA" - 61k Miles - $22k FRSTRM Cars for Sale/Trade 7 01-15-2018 06:21 PM
dealership thats willing to fix timing cover leak for "heavily modified" brz iarefluffy Southern California 14 12-28-2017 11:53 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Issues | Warranty | Recalls / TSB 5 11-28-2017 03:55 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Tracking / Autocross / HPDE / Drifting 7 09-25-2017 03:01 PM
Are there varying levels of engine leaks? Apparently this isn't considered a "leak" tracerit Issues | Warranty | Recalls / TSB 9 05-26-2015 04:02 PM
