Drives: BRZ 2023
Do I need spacers? 2 camber bolts with stock wheels and suspension
I installed whiteline camber bolt on top and SPC camber bolt on bottom on my 2023 BRZ. I can but hardly fit finger in gap between spring and tires on front. Is that enough or I need to get extended bolts and spacers?
Drives: English, French, Swedish & Japanese
Finger width would be fine IMO.
| The Following 4 Users Say Thank You to ACT86 For This Useful Post: |
Drives: Toyota 86
Super fine.
| The Following User Says Thank You to marco_mc22 For This Useful Post: | ruturaj001 (05-28-2023) |
Drives: Toyota GT86
How much camber is that ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
TRACKBREAD
I'd make sure you have 10mm (TUV requirement, so safe starting point).
fingers are too variable for measurement. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | ruturaj001 (05-29-2023) |
Drives: Subaru BRZ
I have the following:
20mm front spacer 25mm rear spacer Camber bolts Super pro rear arm and toe links KW V3 - finger space between top of tyre and front wing... All super duper good!! |
| The Following User Says Thank You to JD001 For This Useful Post: | ruturaj001 (05-28-2023) |
Drives: BRZ 2023
| The Following User Says Thank You to ruturaj001 For This Useful Post: | autoracer86 (05-28-2023) |
Drives: BRZ 2023
Drives: BRZ 2023
I assume you meant distance on outside of the wheel? If so, my question was about inside.
#10 | |
Drives: BRZ 2023
#11 |
Drives: Subaru BRZ
Unsure what the distance was when I had the spacers installed while I still had the original dampers but with Eibach sportline springs. I just wanted the wheels pushed out.. oh I had the alignment done at the time.
#12 |
Drives: BRZ 2023
I ended up ordering 3mm spacer last night, if alignment guy thinks I need it, I would put those on.
| The Following User Says Thank You to ruturaj001 For This Useful Post: | autoracer86 (05-29-2023) |
#13 |
Drives: Toyota GT86
Will you need extended studs as well ?
#14 |
Drives: 17 Asphalt 86
3mm technically clears but doesn't leave much stud left for nut to grab onto. Not sure I'd feel comfortable running that on track but that's me.
Some 2.5" Arps would solve that. |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | autoracer86 (05-29-2023), ruturaj001 (05-29-2023) |
| Camber bolts and stock suspension rub | Cubix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-02-2021 12:46 AM |
| 20mm & 25mm v3 bolt on spacers. Whiteline camber bolts | Newlovekid | Wheels and Tires | 4 | 09-01-2014 01:35 PM |
| Koni/GC Suspension, SPC LCA's, Wilwood BBK, OEM Camber Bolts | SportInjected | Brakes, Suspension, Chassis | 13 | 08-22-2014 08:52 AM |
| Front stock struts/bolts max camber Q.. | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-15-2013 04:45 PM |
| Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. | Shiro86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-14-2013 09:44 AM |
