Old 07-22-2021, 11:49 PM   #1
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Camber bolts and stock suspension rub
I've looked all over and I am finding some conflicting info.
Would a 245/40/17 on 17x8.5 +33 with -2.5 camber using camber bolts up front cause rubbing issues on the spring perch? (Stock struts with Eibach Sportlines)
I'm seeing some reports of 17x9 +35 with -2.5 fitting, some saying its practically close enough to be rubbing. If anyone is running either of these set ups please chime in on the firment!
Cubix is offline   Reply With Quote
Old 07-23-2021, 09:02 AM   #2
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
My track set is 17x9 +40 and I got some 3 mm spacers (so +37?). Without the spacers they would touch. I have -3.2* camber but that's with maxed out camber plates on the stock struts and then camber bolts top & bottom. I would expect 17x8.5 +33 to be ok.
Used to be that wheelitfit.com was the place to go and check (for free), now it looks like you need to pay $3 for access to anything but a Lada.
CrowsFeast is offline   Reply With Quote
Old 07-23-2021, 10:18 AM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I don’t think you’ll get -2.5 with bolts.
Old 07-23-2021, 02:46 PM   #4
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Thanks! I've popped a few users' similar specs into wheelitfit and compared the distance with this set-up and it looks like it should be ok. wheelitfit assumes camber plates unfortunately. It doesn't show how camber bolts would affect geometry.
I think people get that or close with 14mm bottom with OEM crash bolts top.
The Following User Says Thank You to Cubix For This Useful Post:
TommyW (07-23-2021)
Old 07-27-2021, 08:40 AM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
My memory is a bit fuzzy, but I think I used 16mm camber bolts and crash bolts up top and got -1.9 deg.
dragoontwo is offline   Reply With Quote
Old 08-01-2021, 07:23 PM   #6
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
YMMV, but my shop was able to get me -2.2 in the front with SPC camber bolts in the lower hole and moving the stock bolts to the upper hole. Stock PP suspension otherwise.
NaturallyAspirated is offline   Reply With Quote
Old 08-01-2021, 08:56 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
I got -2.0 on one side and -2.2 on the other with SPC bolts on both holes - 16mm top and 14mm bottom.
Ohio Enthusiast is offline   Reply With Quote
Old 08-02-2021, 12:46 AM   #8
TommyW
TommyW's Avatar
Just get plates. You’ll have a lot more options and it’s a lot easier to dial things in
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
Looking for: Stock Rear Struts & OEM front crash/camber bolts Rifle Mid-Atlantic 3 09-20-2017 10:50 PM
Koni/GC Suspension, SPC LCA's, Wilwood BBK, OEM Camber Bolts SportInjected Brakes, Suspension, Chassis 13 08-22-2014 08:52 AM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. Shiro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-14-2013 09:44 AM
