Old 05-25-2023, 02:19 PM   #1
toeout
FS: APEX VS-5RS 17x9 +48 Anthracite wheels
Sold.
toeout is offline   Reply With Quote
Old 05-25-2023, 02:21 PM   #2
Garrett86
Garrett86's Avatar
Drives: 2014 Scion FR-S
Pics on car?
Garrett86 is offline   Reply With Quote
Old 05-25-2023, 03:42 PM   #3
toeout
I sold the car before I managed to take any.
Originally Posted by Garrett86 View Post
Pics on car?
Old 06-02-2023, 09:11 AM   #4
toeout
Price drop.
Old 06-06-2023, 12:08 PM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Dang, this is a good deal.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-06-2023, 06:25 PM   #6
ihavefat
Drives: 2018 BRZ
Wish this fit 1st gen on stock shocks/springs. . It’s my understanding the higher offset is for the 2nd gen
ihavefat is offline   Reply With Quote
Old 06-06-2023, 06:44 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Absolutely will not fit, even with 3mm spacers it will not fit.
Originally Posted by humfrz
I'm old and lazy
Old 06-06-2023, 07:52 PM   #8
billstock67
Drives: 2017 Toyota 86
How much spacer would be required?
billstock67 is offline   Reply With Quote
Old 06-07-2023, 01:26 AM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
I ran 17x9 +42 up front with OEM spring perch, it's doable if your 245/40 tire doesn't run wide, like these A052s here do.
However, it's not ideal to run that much tire up front on a wide wheel if you can't dial in useful negative camber. With stock top hats, I couldn't do much up front (crash bolts would've just moved the wheel and tire closer to the edge of the spring perch) which kinda negated some of the benefits of having that wheel and tire setup. It still handled great, it was just leaving a lot on the table.
Ideally you'd want to run -2 degrees of camber up front with a 17x9 245/40 setup. So you're looking at aftermarket suspension bits if you want to "do it once, do it right."
I'm old and lazy
Old 06-07-2023, 09:37 AM   #10
toeout
For reference - On gen.2, I ran these wheels with coilovers and 13mm spacer up front / no spacer in the back. -4.5 deg camber front / -2.2 deg camber in the back.
Old 06-18-2023, 11:24 AM   #11
toeout
Price drop and new pictures without tires.
Old 06-18-2023, 04:47 PM   #12
Stevo22
Stevo22's Avatar
Drives: GR86
Sent pm
Stevo22 is offline   Reply With Quote
FS: Apex ARC-8 17X9 +42 Anthracite sold stiboss Wheels and Tires 3 11-20-2022 12:33 PM
FS: Apex EC-7R 17X9 +42 Anthracite toeout Wheels and Tires 6 08-11-2022 04:00 PM
FS: NIB Apex ARC-8 17x9 +35 Anthracite (CA) BRZ Hachi Wheels and Tires 0 03-31-2022 08:25 PM
Sold! - FS: APEX ARC-8 (Anthracite) 17x9 +42 w/ 245/40/17 Michelin Pilot Super Sports Lord09 Wheels and Tires 11 09-30-2016 01:36 PM
