FS: APEX VS-5RS 17x9 +48 Anthracite wheels
Sold.
| The Following User Says Thank You to toeout For This Useful Post: | Wally86 (06-06-2023) |
#2 |
Drives: 2014 Scion FR-S
Pics on car?
#3 |
#4 |
Price drop.
#5 |
Be Kind
Drives: 2020 86
Dang, this is a good deal.
| The Following User Says Thank You to Wally86 For This Useful Post: | toeout (06-06-2023) |
#6 |
Drives: 2018 BRZ
Wish this fit 1st gen on stock shocks/springs. . It’s my understanding the higher offset is for the 2nd gen
#7 | |
Proud of BOXER
Drives: Subaru Boxer
Absolutely will not fit, even with 3mm spacers it will not fit.
| The Following User Says Thank You to Clipdat For This Useful Post: | ihavefat (06-06-2023) |
#8 |
Drives: 2017 Toyota 86
#9 | |
Proud of BOXER
I ran 17x9 +42 up front with OEM spring perch, it's doable if your 245/40 tire doesn't run wide, like these A052s here do.
However, it's not ideal to run that much tire up front on a wide wheel if you can't dial in useful negative camber. With stock top hats, I couldn't do much up front (crash bolts would've just moved the wheel and tire closer to the edge of the spring perch) which kinda negated some of the benefits of having that wheel and tire setup. It still handled great, it was just leaving a lot on the table. Ideally you'd want to run -2 degrees of camber up front with a 17x9 245/40 setup. So you're looking at aftermarket suspension bits if you want to "do it once, do it right."
#10 |
For reference - On gen.2, I ran these wheels with coilovers and 13mm spacer up front / no spacer in the back. -4.5 deg camber front / -2.2 deg camber in the back.
#11 |
Price drop and new pictures without tires.
| FS: Apex ARC-8 17X9 +42 Anthracite sold | stiboss | Wheels and Tires | 3 | 11-20-2022 01:33 PM |
| FS: Apex EC-7R 17X9 +42 Anthracite | toeout | Wheels and Tires | 6 | 08-11-2022 05:00 PM |
| FS: NIB Apex ARC-8 17x9 +35 Anthracite (CA) | BRZ Hachi | Wheels and Tires | 0 | 03-31-2022 09:25 PM |
| Sold! - FS: APEX ARC-8 (Anthracite) 17x9 +42 w/ 245/40/17 Michelin Pilot Super Sports | Lord09 | Wheels and Tires | 11 | 09-30-2016 02:36 PM |
