Drives: 2018 Subaru BRZ
(1st Gen) Engine, Transmission and Diferential Washers
For sticky purposes.
Below the list of washers required when performing maintenance on both 86 and BRZ.
1st Gen BRZ:
ENGINE -Engine Oil Pan Drain Plug Gasket: P/N 803916010 -Drain Plug (If Damaged) : P/N 807016160 TRANSMISSION -Fill Plug (If damaged): P/N 17007AA230 -Drain Plug Gasket: P/N 17008AA050 -Drain Plug (If damaged): P/N 17007AA070 DIFFERENTIAL -Fill Gasket: P/N 11126JB000 -Fill Plug (If damaged) : P/N 15027JB010 -Drain Plug Gasket: 1215710010 -Drain Plug (If Damaged) : P/N 9034118035
Saved for 1st Gen Toyota
@ichitaka05 sticky please! Just need to do research on the Toyota side. I'll check if the same parts are used on 2nd Gens
| The Following User Says Thank You to spcmafia For This Useful Post: | ichitaka05 (05-12-2023) |
Wheels for Brains
Gen 1
Part Name (Colloquial) | Part Name (Catalog) | Subaru PN | Toyota PN Oil Drain Gasket | GASKET OIL DRAIN PLUG/DRAIN PLUG GASKET | 803916010 | SU00302159 Transmission Fill&Drain Gaskets | GASKET/GASKET, DRAIN PLUG(MTM) | 17008AA050 | SU00303626 Differential Fill Gasket | GASKETDRAIN PLUG | 11126JB000 | SU00300122 Differential Drain Gasket* | GASKET | 1215710010 | 1215710010 Note*: Yes, for the Diff drain gasket, the Subaru and Toyota PNs are the same in both inventory systems |
| The Following 5 Users Say Thank You to EndlessAzure For This Useful Post: | bcj (12-10-2023), menikmati (12-11-2023), RedReplicant (12-10-2023), spcmafia (12-10-2023), x808drifter (12-10-2023) |
| Diff and Transmission Gaskets/Crush washers | Lakitu | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-11-2018 11:59 PM |
| Manual Transmission + Differential Drain Bolt Crush Washers | skylinekin | Transmission and Driveline | 0 | 12-27-2017 04:22 PM |
| Transmission&Diff crush washers reusable? | BDKane01 | Issues | Warranty | Recalls / TSB | 3 | 07-11-2016 03:33 PM |
| transmission or diferential peoblem? CLICK/TICK | subiesteve | Issues | Warranty | Recalls / TSB | 38 | 08-17-2013 09:20 PM |
| Can the transmission crush washers be reused? | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 04-15-2013 07:35 PM |
