Old 05-11-2023, 01:58 AM   #1
LVL_UP
LVL_UP's Avatar
Drives: 2013 Hot Lava FRS
FS: FRS Auto Climate Control Conversion Harness
This harness is for adapting the BRZ auto climate control into your manual control FRS/BRZ. Can be used for dual or single temp installs, depending on how ambitious you want to be. This is my take on the harness that was the focus of this thread:
https://www.ft86club.com/forums/show...10#post2332310
Price: $350 Shipped in continental US
4 harnesses are available
I will also be including basic installation instructions for the harness and the parts for single temp.
The single temp install is “easy” and does not require any major modifications, but you still need to remove the center console, glovebox, and dashboard to install all the conversion components.
Dual temp generally requires disconnecting AC and heater core, along with needing to loosen/remove the dash bar in order to replace the HVAC housing with a dual temp unit. *I have not personally done the dual temp install, so there could be more involved.
These harnesses use 18ga XLPE coated wire, covered with PET sleeving secured by adhesive lined heatshrink. White electrical tape just secures extra heatshrink for use during install.
For Single temp, these parts are also required:
Driver side Temperature Servo SU003-02045
Damper Servo SU003-02044 - Verify it has the metal bracket
New Blower Motor Resistor 73533AJ000
Temperature Sensor 73730CA020
Temp Tube 72313CA010
Screws for Servo installation (Order 5) SU003-02113
Auto Climate Control panel 72311CA061
LVL_UP is offline   Reply With Quote
Old 08-29-2023, 12:57 AM   #2
tx.pete86_
tx.pete86_'s Avatar
Drives: 2017 Toyota 86
This is sick! I would definitely be interested in a harness if you still have one available.
tx.pete86_ is offline   Reply With Quote
Old 08-31-2023, 04:43 PM   #3
LVL_UP
LVL_UP's Avatar
Yes, I still have a couple available. PM Sent
Old 02-19-2024, 10:32 PM   #4
LVL_UP
LVL_UP's Avatar
Bump
Have one left ready to ship
Old 06-06-2024, 10:46 PM   #5
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
Interested! Let me know if you have one available.
Winona, My Wingless Angel
Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback
Arcadien Angel is offline   Reply With Quote
Old 11-23-2024, 06:08 PM   #6
lextrueno
lextrueno's Avatar
Drives: 2013 Firestorm Frs
Originally Posted by LVL_UP View Post
Bump
PM'D
lextrueno is offline   Reply With Quote
Old 07-07-2025, 02:39 PM   #7
DVNARC
Drives: 2013 Black Scion FRS
hello do you still have the harness for sale?
my email is alexandersaponte@gmail.com
DVNARC is offline   Reply With Quote
Automatic dual climate control harness Sangthing Electronics | Audio | NAV | Infotainment 209 05-19-2023 12:16 AM
Climate Control Conversion Codythatsme DIY (Do-It-Yourself) Guides 13 07-07-2015 03:58 PM
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 04:11 PM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
