Old 05-08-2023, 10:35 AM   #1
steverife
Drives: 2016 Scion FRS
Ignition Coil Connector Clip Part Number
2016 FRS. Coil pack or ignition coil or whatever you want to call it snaps into the connector. There is a tiny metal clip that holds the connector in place.
Assuming it is sold seperately, does anyone have a part number for this piece?
steverife is offline   Reply With Quote
Old 05-08-2023, 11:08 AM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Buy this and de-pin your OEM connector and re-pin into this.
OR
Buy this and remove the metal clip/spring from the new one and save the plastic harness part in case you ever damage one that's already on the car. You can't see the spring clip in the picture on their site but trust me it's there.
https://www.icefabrication.com/produ...ing-only-2015/
Joon525 is offline   Reply With Quote
Part Number for Horn Connector Bonburner Electronics | Audio | NAV | Infotainment 3 11-10-2023 02:56 AM
Part number for window switch connector terminal? HRTROB Cosmetic Modification (Interior/Exterior/Lighting) 5 02-27-2023 07:44 AM
USB (IPOD) Dash Connector Part Number Question SilentMike Cosmetic Modification (Interior/Exterior/Lighting) 0 07-14-2013 04:29 PM
Does anyone know the clip part number? t00n3wb Cosmetic Modification (Interior/Exterior/Lighting) 1 05-20-2013 12:28 AM
Part number or name for this clip TrickyFrenchman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-16-2012 10:50 PM
