Drives: Toyota 86
Part number for window switch connector terminal?
I'm trying to retrofit a USDM passenger door lock/window switch to my 2013 86 because mine doesn't have the door lock/unlock button. I already have the USDM switch panel and it's plug and play with my harness. I've studied the wiring diagram and I only need to hook up pins 15 and 16 on my passenger switch connector to the wires on the same pins on the driver side. I need the female terminals that will slide into the empty terminals on my passenger switch socket. Anyone know the part number or an aftermarket source for those pins?
#2 | |
Wheels for Brains
Bump. Also looking for this info regarding the female wire terminals for power window switch Even a trade name or specification insights would be helpful It doesn't seem to be a standard Toyota or Subaru connector, so it doesn't show up on connector diagrams. However, it's a somewhat common connector and used on window switches for other Subarus and Japanese auto makes |
ProCrastinationConsultant
i would recommend contacting a junk yard and getting them to cut off the harness from a wrecked model.
Be Kind
Drives: 2020 86
This looks a lot like it but I'm having difficulty getting a real part number for the connector.
https://www.amazon.com/Assembly-Conn...dp/B08BJ3WX2D/
#5 | |
Drives: 2013 Subaru BRZ
Be Kind
Drives: 2020 86
#Legend
| Part number for fusible link block on positive battery terminal? | Jack Black | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 08-24-2022 08:58 AM |
| Got hit (bumped)! Need part number for the black part of bumper. | scottsampaio.com | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-25-2014 12:05 AM |
| Part # Needed Cluster Surround & Window Switch Covers | Brody602 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 12-25-2013 11:19 AM |
| Part number request for heated seat switch trim | azian_advanced | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 09-13-2013 11:02 PM |
| USB (IPOD) Dash Connector Part Number Question | SilentMike | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-14-2013 04:29 PM |
