Old 05-01-2023, 05:01 AM   #1
YCK
Drives: Toyota 86 GTS 2019
Oil Pressure via CPC Input (Ecutek)
Hi,
I am trying to get the oil pressure logged in Ecutek via the CPC input with no luck. I am hoping someone here can point me in the right direction.
. I had this sensor installed: https://www.bosch-motorsport-shop.co...-10-bar-140-de
. It is grounded to the car chassis, powered via the ECU and pinned to the CPC Input.
. In Ecutek the CP sensor input was overwritten to use the CPC input and 2D table updated for the conversion of voltage to Pressure.
. The oil pressure sensor is working properly and the right voltage is sent to the ECU (confirmed via a multimeter, at the pin)
Looking at the data logged in ECUTEK the reading is showing a flat 10 bar all the time. Looking at the raw input via the parameter CPS voltage, it oscillates between 4.98V and 5V
Looking at the previous posts https://www.ft86club.com/forums/showthread.php?t=61573 and https://www.ft86club.com/forums/showthread.php?t=94751
It looks like the input is not working, hence always reading 5V.
I have a 2019 Australian 86.
Any idea what is missing in my setup for this to work?
Thank you!
YCK is offline   Reply With Quote
Old 05-01-2023, 06:20 AM   #2
tomm.brz
Drives: brz 2017 hksv2
I think not working would give 0 instead of 4.98-5v
Did you hook up the output of the sensor to the correct cpc input pin in the ecu?
Old 05-01-2023, 07:10 AM   #3
YCK
Yes I checked the pin was in the correct input.
From that thread https://www.ft86club.com/forums/showthread.php?t=94751
It says
Without a connection to a sensor, the voltage is pulled up and logs ~5V (~940mmHg).
Old 05-01-2023, 07:21 AM   #4
tomm.brz
yes for a open circuit will give 5v actually
could be the fact you have a restyling car
i m not familiar with cpc input unfortunately, but for example the rear o2 input got weird in restyling cars and it doesnt work as in prerestyling as subaru changed the way it s grounded
so to make it work you would connect the ground of a sensor into rear o2, both to the ground itself of the connector AND then bridge it into chassis ground
otherwise doesn t work
could be something similar with cpc input, if you connected chassis ground, the ecu could not see it and think the input is an open circuit and give u 5v
The Following User Says Thank You to tomm.brz For This Useful Post:
YCK (05-01-2023)
What does Ecutek variable “Fuel Rail Pressure MPA” represent (no startup)? Eazy-V Software Tuning 7 05-20-2022 09:11 AM
Input dholloway543 Forced Induction 17 11-20-2019 08:28 AM
Need some input LOOK!! skavengers412 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2016 12:50 PM
Oil Pressure Safety Trip with EcuTek RaceROM Custom Maps EcuTek Software Tuning 2 10-09-2015 08:55 AM
oil pressure logging with ecutek twag4 Software Tuning 6 09-24-2015 02:34 AM
