Old 05-04-2022, 04:52 AM   #1
Eazy-V
What does Ecutek variable “Fuel Rail Pressure MPA” represent (no startup)?
My FRS currently is cranking but not starting, so here are 2 datalogs
CURRENT (cranking with no startup): https://datazap.me/u/eazy-v/2013-frs...g=0&data=12-17
2018 (startup fine): https://datazap.me/u/eazy-v/2013-frs...g=0&data=12-17
Any ideas of what might wrong?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 05-04-2022, 05:49 AM   #2
steve99
Fuel rail pressure monitored is the DI fuel rail pressure.
unlike fhe port injection pump in tank that is regulated to aprox 60psi constant, the di fuel rail pressure is variable and controlled the the DI computer and engine ecu to vary the di fuel rail pressure depending on di demand, the di system manages both pressure and injectpr pulse width to deliver required amount of fuel
Old 05-04-2022, 05:51 AM   #3
steve99
These cars start on 100% port injection
but ensure all bolts are in and tight on DI computer on side of engine
Old 05-04-2022, 02:36 PM   #4
Eazy-V
Ok I’ll check that
So, would this indicate that the in-tank fuel pump has to be working since it would be sending fuel up to the DI pump? Or is the DI pump on a separate fuel line to the gas tank?
Old 05-05-2022, 07:04 AM   #5
steve99
Originally Posted by Eazy-V View Post
Ok I’ll check that
there is no monitoring on the in tank low pressure pump you would need to T into fuel line and measurecfuel pressure should be round 60 psi.
The di pump is mechanical pump fed from intank pump but im pretty sure it will just draw fuel through the in tank pump even if its low pressure or bot working
Old 05-05-2022, 11:01 AM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Can you give it a little squirt of starter fluid? If it "tries" to start you then know it's a fuel problem. If not then check your Flux Capacitor.
Old 05-20-2022, 08:54 AM   #7
Eazy-V
Got it resolved, found that the inline fuse on my Deatschwerks fuel pump hardwire kit was completely melted
Old 05-20-2022, 09:11 AM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
That's a sign that something is terribly wrong, I would figure that out before hardwiring again.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
P0087 Low Fuel rail pressure GT86meMR2 Issues | Warranty | Recalls / TSB 17 05-15-2021 01:23 PM
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 07:38 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
direct injector injection/rail pressure? WHITE Engine, Exhaust, Transmission 2 07-10-2015 02:06 PM
frs low fuel rail pressure ? 15,000 miles j0hnnybk01 Issues | Warranty | Recalls / TSB 10 03-04-2014 03:03 PM
