Old 04-24-2023, 12:07 AM   #1
Bergycheese348
Bergycheese348's Avatar
Drives: TRD Supercharged 2016 FR-S
Endlink making contact with lower control arm
SO, I have had AST 5100 suspension since November of 2022, and because my end links were too long (stock), I was running without end links for a while. About a month ago I was able to put my Whiteline end links on, which was purchased from the guy who had the AST suspension. He had no problems with it at all and hadn't touched either since taking them off of his car, but when I put them on they are clunking really bad, and are making contact with the lower control arm (when I was finally able to take a look at them). I know this because the paint is clearly removed on the control arm. I am also running TRD sways (USDM red ones). Now, as for a solution, do they have to be shorter or longer because it is a change in sway bar height, or is there something I am missing. Any help helps. Thanks!
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace
Bergycheese348 is offline   Reply With Quote
Old 04-24-2023, 12:23 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Pictures would help. Some sway bar and strut combos need shorter endlinks and some need longer. Try to get a picture from inside the wheel well with the car on the ground and steering straight (might not be possible). Also, a picture of the control arm where it's hitting.
When does it clunk? Did you adjust the endlinks to remove preload at all? Is it hitting on both sides or just one?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
Clipdat (04-24-2023)
Old 04-24-2023, 08:14 AM   #3
Bergycheese348
Will grab a few photos when I have some time (been a bit busy with school). As for when does it clunk; it clunks when turning and when hitting bumps (Michigan roads, so a lot of bumps). With turning, it varies when it clunks, as sometimes it get close to lock to lock without clunking, other times 45º makes it clunk, but it clunks less when moving in terms of turning. Also, I am not 100% sure it is making contact on both sides, but it seems to sound like it is coming from both sides. As mentioned, the end links/suspension were not touched at all between being removed from the previous owners car and my car, and the steering was straight when they were installed, so sway bars should not have been loaded.
T RD, Verus, Ace
Old 04-24-2023, 08:24 AM   #4
whataboutbob
AutoX-10/10ths every run
I had a similar problem with the WL front end links and a WL front sway.
You'll want these (https://www.splparts.com/products/fr...t-version.html) to solve your problem.
Build thread:Here
Old 04-24-2023, 08:50 AM   #5
Spuds
The Dictater
Spuds's Avatar
Yeah, my guess is you will want to go shorter to get the ends of the bar above the control arm. Just not too short because then you will start hitting the body. You might be able to get away with shortening the endlinks you have through adjustment, or you may need to get shorter endlinks.
If you have a different bar than the seller, then what worked for his car may not work for yours. Clearance is tight in the wheel well, a millimeter or two can make the difference.
Bergycheese348 (04-24-2023)
Old 04-24-2023, 08:51 AM   #6
Bergycheese348
Actual contact between the end link and control arm? I have heard they have had issues with the nuts coming loose and causing clunking, but have notheard of actual contact, which I would think is the main issue.
T RD, Verus, Ace
Old 04-24-2023, 11:20 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Almost all aftermarket endlinks have this issue. I always recommended double nutting them. I blocked my car up and measured strut to swaybar with no end link attached and ordered one from WL that fit. The standard one was too long on my car with T2's.
Old 04-24-2023, 05:21 PM   #8
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
This is what you need....thinest, strongest adjustable endlinks for the 86 chassis
https://www.hotchkis.net/product/hot...13-subaru-brz/
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-24-2023, 09:23 PM   #9
whataboutbob
No, the excessively long end link puts the sway bar in a position where the control arm and sway come into contact. The SPL part is shorter, which solved this problem for me.
Build thread:Here
Old 04-25-2023, 04:09 PM   #10
redlined600
redlined600's Avatar
Drives: Fr-s
I had the same issue with stock end-links. As an additional option, the Racerx endlinks worked well length-wise with RCE T2 struts.
Old 04-29-2023, 07:55 PM   #11
FrickingReallySlow
Drives: 2015 FR-S
Hey guys what is the neutral position for the OE front swaybar since it as a curve at the end? Is the imaginary "A" line suppose to be parallel to the ground or is the the "B" line suppose to be parallel to the ground. Rear sway bar doesn't have the bend so its easy to asses the neutral position
Also does the above recommendations for SPL / Hotchkis front end links work with a 1" lowered Tein FlexZ and OE sway bar as well?
FrickingReallySlow is offline   Reply With Quote
Old 04-29-2023, 10:51 PM   #12
strat61caster
strat61caster's Avatar
A is parallel-ish, bar bends over steering rod. It is currently approximately 180 degrees out from where it should be in your picture.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
FrickingReallySlow (04-29-2023), nomtimesthree (10-26-2024), whataboutbob (04-30-2023)
Rear lower control arm endlink/shocks ratio adjustments Brzerker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-05-2018 12:05 AM
Catback exhaust making contact with rear diff gMit Engine, Exhaust, Transmission 9 02-22-2016 03:47 PM
PBM adj. lower control arm!!!! Grip Ronin Brakes, Suspension, Chassis 13 10-30-2015 12:27 AM
is there a shorter endlink out there? mcs motion control damper toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2014 07:28 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
