RCE Yellow to Tarmac Springs
Hi,
I’m planning on swapping out the yellows for Tarmac springs and reusing my Koni Sport dampers and Pedders top hats. Will spring compressors be needed for this project? Thanks! |
It's easier and safer to use them then try and not use them.
| The Following User Says Thank You to strat61caster For This Useful Post: | macuser27 (04-13-2023) |
I just refreshed my Tarmac + Pedders + Bilsteins and did not need spring compressors for front or rear. You should be good without them too.
But yes going to oreillys to get the compressors is good for peace of mind. |
| The Following User Says Thank You to norcalpb For This Useful Post: | macuser27 (04-13-2023) |
Drives: 17 Asphalt 86
Needed no, but it would make reinstallation of pedders top nut a lot easier.
Without a compressor It is sort of an awkward job but doable. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | macuser27 (04-13-2023) |
Also please share your impressions if you notice any significant differences between the springs
| The Following User Says Thank You to norcalpb For This Useful Post: | yberther (04-27-2023) |
| Koni Yellow/RCE Tarmac Review | rapidcars | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-25-2018 02:16 PM |
| [PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs | leunglambs | NY / NJ / CT / PA | 3 | 06-09-2017 02:49 PM |
| Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks | Kyogre | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 05-12-2015 04:59 PM |
| Koni yellow/RCE tarmac setup-initial review | ncmx5 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-12-2014 12:55 PM |
| WTB: Koni yellow struts and RCE yellow springs | nlowell | Brakes, Suspension, Chassis | 2 | 05-20-2014 03:10 PM |
