Old 12-08-2014, 03:37 AM   #1
ncmx5
ncmx5's Avatar
Drives: 2013 BRZ premium
Koni yellow/RCE tarmac setup-initial review
I have been running Koni yellows with stock springs and factory camber bolts for almost entire autox season and it was great, but so far the new springs feel sooo much better than it did before. I thought it was going to be a really rough ride but it actually is alot smoother than running the stock springs, im guessing the shocks don't have to do all the work now that the tarmac springs are better matched.... I also installed the whiteline camber bolt kit but haven't gone in for the alignment yet im hoping for at least -2 but ill see. so far this seems like a great setup for autox and track.
Ill post more impressions once I can get the car on track and I put on the BFG rivals once the worst of TX winter is over.
ncmx5 is offline   Reply With Quote
The Following 3 Users Say Thank You to ncmx5 For This Useful Post:
finch1750 (12-08-2014), fstlane (12-08-2014), Racecomp Engineering (12-08-2014)
Old 12-08-2014, 04:19 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Glad to see. I have the yellows but have been wondering if the move to tarmacs is worth it.
Combine factory camber bolts with spcs if you need more camber. I run them on a rce/koni setup and can get around -2.5 in the front.
Old 12-08-2014, 04:27 AM   #3
ncmx5
ncmx5's Avatar
Yeah i was thinking ground control camber/caster plates if i dont get to my desired camber, but so far the car is sooo much fun !!! I really cant get a full review impression until i get it on track.
Old 12-11-2014, 06:28 PM   #4
ncmx5
ncmx5's Avatar
Just got my alignment done only got -1.5 in the front .... feels great on the street but an autox with new tires should be awesome,I will be getting some camber/caster plates if I still have low speed understeer.
Old 12-12-2014, 12:55 PM   #5
finch1750
finch1750's Avatar
Your probably gonna need more. I understeered with anything less than -2. But that is on a less sticky tire (bridgestone s-04)
FS: HVT Top Hats, Koni Struts, RCE TARMAC Springs Trefoil Brakes, Suspension, Chassis 2 08-08-2014 10:06 AM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
Review: RCE Yellow Springs and KONI shocks Grimlock Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 03-27-2014 10:58 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
