Old 04-24-2018, 10:55 PM   #1
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Koni Yellow/RCE Tarmac Review
Setup: Koni Yellows, RCE Tarmacs, SPC Lower Controls Arms, SPC Front Camber Bolts, 17x8 O.Z. UltraLeggerras with 225/45/17 Michelin PSS, Camber (See Picture below)
Just installed today. I was originally going to go with Bilstein B8s but they were back-ordered through June and my stock suspension was shot at 73k miles. This is for my daily driver that sees occasional auto x use.
Ride
I was extremely surprised and pleased with how well this setup feels on the road. I was nervous it would be overly harsh or bumpy but it is neither. It handles pot hole ridden NY roads extremely well and I immediately realized just how worn my stock suspension was. From what I remember, it is very close, if not better than the stock suspension when new. The Konis are set to the softest setting so that is probably helping a bit.
Handling
Wow, wow, wow! To think I used to think the stock suspension didn't have any body roll. The car is so much more composed and just begs to be pushed. Towards the limit and at high speeds, understeer is greatly reduced and the car is just so much eager to turn but the limit is so high I probably haven't even come close to it yet. Will need to wait until I auto x to really tell how it compares. Only downside is at low speeds, the car doesn't seem to rotate quite as well due to the flatter suspension and sticky tires.
Aesthetics
Much much better than stock but from a purely cosmetic perspective, it could use another 1/2 inch to an inch more drop. It looks like a sports car should come from the factory but doesn't look noticeably lowered if that is what you're going for. I'm fine with it as it considered to be the optimal height for handling purposes but if you're looking for that lowered look, keep that in mind.
Overall
I'm extremely happy with the setup. I'm glad I got to experience the stock setup but regret not doing this sooner. Thanks to @Racecomp Engineering for making a great spring and helping out with camber suggestions.
Before:
After:
Camber Settings
rapidcars is offline   Reply With Quote
The Following 4 Users Say Thank You to rapidcars For This Useful Post:
Racecomp Engineering (04-25-2018), smg1138 (04-25-2018), Tristor (04-25-2018), wparsons (04-25-2018)
Old 04-25-2018, 10:31 AM   #2
JMon85
JMon85's Avatar
Drives: 2019 WRX
Very nice!! What offset for your ultraleggera?
JMon85 is offline   Reply With Quote
Old 04-25-2018, 10:36 AM   #3
Daaaamn. Good shocks, good springs, good alignment, good wheel/tire combo....serious thumbs up from me!
Doing it right.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
norcalpb (04-25-2018), rapidcars (04-25-2018)
Old 04-25-2018, 01:19 PM   #4
norcalpb
norcalpb's Avatar
Nice setup. I had the same for 70k miles before my Konis blew. I’m still using the Tarmac springs nearly 100k miles later!
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
Racecomp Engineering (04-25-2018), rapidcars (04-25-2018)
Old 04-25-2018, 01:35 PM   #5
rapidcars
rapidcars's Avatar
Thanks! 48mm offset.
The Following User Says Thank You to rapidcars For This Useful Post:
JMon85 (04-25-2018)
Old 04-25-2018, 02:16 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Congrats and nice setup. Car looks good.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 04:59 PM
Koni yellow/RCE tarmac setup-initial review ncmx5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-12-2014 12:55 PM
Review: RCE Yellow Springs and KONI shocks Grimlock Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 03-27-2014 10:58 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
