Old 04-11-2023, 07:30 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Pinion depth
What yall think run it? I was told don’t worry about centering between toe and heel. Used stock shim since it gave the best pattern so far
IsaiahW is offline   Reply With Quote
Old 04-11-2023, 10:08 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
sure seems like a lot of slop between drive/coast. is your lash within spec?
the overall pattern looks like it has good contact according to the examples you posted.
Old 04-12-2023, 03:06 PM   #3
IsaiahW
IsaiahW's Avatar
I didnt focus on backlash on that one like i shouldve so i wasnt in spec but i got it within spec at .009 thou heres the results. Im not sure if i need to make more changes i tried to make tiny adjustments but it just threw it off
Old 04-12-2023, 04:12 PM   #4
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
That is similar to how I set my last Cobra up, the only concern is if you can handle some whine with it. Contact patch looks OK just a little tight on the pinion depth.
EvilPenguin04 is offline   Reply With Quote
Oil Cooling - An In-Depth Look VerusEric Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 115 02-20-2023 10:54 PM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Depth of Speed series. Superhatch Other Vehicles & General Automotive Discussions 0 07-11-2014 02:10 PM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 01:13 PM
AE86: An In-Depth Look at A Legend Axel Scion FR-S / Toyota 86 GT86 General Forum 25 01-26-2010 10:44 PM
