Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-11-2023, 12:44 PM   #1
omoulton
Drives: 2023 BRZ
No threads 2023 front license plate holes
Has anyone else discovered the holes aren't threaded? I bought the JDM <> USDM adapter mentioned in here. When to attach and so sorry.
Any creative work arounds besides a tow hook plate holder?
Thanks
omoulton is offline   Reply With Quote
Old 04-11-2023, 02:01 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
There's a nut plate that goes in from the backside. It is possible to push them out. I might have mine somewhere at home that you can have if you want them.
dragoontwo is offline   Reply With Quote
Old 04-11-2023, 02:37 PM   #3
omoulton
Drives: 2023 BRZ
Thank you Sir. It didn't look reachable w/o removing the bumper but I gave it a quick look. I'll look closer to see if it did get pushed out somehow. Thanks again.
Old 04-11-2023, 04:12 PM   #4
dragoontwo
dragoontwo's Avatar
They look like this when you push them out.
Old 04-11-2023, 06:39 PM   #5
cueball89
Drives: 15 Impreza
My 23 didn't have them either. I bought rivet nuts from Mcmaster Carr and glued them in. I didn't want to spring for the rivet nut tool. Seems to be holding up so far.
cueball89 is offline   Reply With Quote
Old 04-11-2023, 07:31 PM   #6
CaptainFenderbaum
Drives: women crazy
My 23 didn't come with them either. Maybe they stopped including them on export models.
CaptainFenderbaum is offline   Reply With Quote
Old 04-11-2023, 07:32 PM   #7
CaptainFenderbaum
Drives: women crazy
Looks like you can pick up a replacement bracket fairly inexpensively
https://parts.subaru.com/p/Subaru_20...7722SG070.html
Old 04-13-2023, 05:28 PM   #8
omoulton
Drives: 2023 BRZ
I appreciate the replies. Thanks folks!
Old 04-15-2023, 12:44 AM   #9
Up4speed
Drives: 2023 BRZ Limited
Mine didn't come threaded either. If you buy the front plate mounting kit from the BRZ accessory brochure, it comes with the proper expandable inserts to install the bracket onto the front bumper. They work great. My recommendation when trying to insert them is to wet them, then use a small screw driver to push them in. If you use that technique they will pop in there in seconds, otherwise you will be fighting with them.
The bracket looks and fits great. The best part is that there is zero damage to the car.
Up4speed is offline   Reply With Quote
Old 04-18-2023, 07:22 AM   #10
omoulton
Drives: 2023 BRZ
@ Up4speed
Thanks for the tip. Which kit are you referencing from the accessory brochure?
Old 04-18-2023, 03:24 PM   #11
Up4speed
Originally Posted by omoulton View Post
@ Up4speed
https://www.subaru.com/content/dam/s...s_Brochure.pdf
Bottom left of page 17
Old 04-19-2023, 08:24 AM   #12
omoulton
Drives: 2023 BRZ
Thank you very much. I thought that was the case and appreciate you confirming!!
Help covering front bumper license plate holes JLMIAMI Cosmetic Modification (Interior/Exterior/Lighting) 56 01-27-2018 05:39 PM
Plugging up license plate bumper holes? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 10 04-12-2015 03:06 PM
Front license plate holes JayBoii Cosmetic Modification (Interior/Exterior/Lighting) 1 12-25-2014 10:03 PM
No Holes License Plate Review! HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-10-2012 05:44 PM
License plate holes - Dealer installed for sure? FastLap Scion FR-S / Toyota 86 GT86 General Forum 28 08-05-2012 03:20 AM
