Old 04-02-2023, 11:51 AM   #1
Bnagy
Drives: Gray FRS
Help with wheel offset/tire size.
I have a 2013 FRS with stock suspension. I do plan to add coil overs soon, though. I am going to buy the AVID1 AV20s 18x8.5 or 9.5”. What I am looking for is a bit wider tires in the rear than up front. I would like the wheels and tires flush with the fender. Any input on what wheel width, offset and tire size would be great. Thanks in advance.
Bnagy is offline   Reply With Quote
Old 04-03-2023, 01:31 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Everything you need to know has been documented here: https://www.ft86club.com/forums/showthread.php?t=7535
EndlessAzure is offline   Reply With Quote
Old 04-03-2023, 07:14 AM   #3
Bnagy
Drives: Gray FRS
Thank you!
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Anybody running 255/35R18 tire on +45 offset wheel in front? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-08-2018 12:27 AM
BRZ STi Alloy Wheel Size and Offset? artongdou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-09-2017 07:17 PM
Desired Wheel Size, Width, Offset - OPINIONS CSG David Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-21-2014 12:02 AM
Help with wheel\tire size for a DD on Pro Kit B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-08-2014 01:06 PM
