Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-01-2023, 11:43 AM   #1
Rob2042
Drives: 2023 WR Blue BRZ Premium Automatic
Brakes
Hi, new member here. Just picked up my 2023 BRZ and am really impressed with it. However, it seems to take quite a bit of pressure to brake. I'm comparing it to my Mazda MX-5 and my 370z I traded in. In fact, it seems to take the most pressure of any of the cars I've owned. Have any of you noticed the same and is there a way to improve the braking so as not to take so much pressure other than replacing the brakes? Thanks
Rob2042 is offline   Reply With Quote
Old 04-01-2023, 12:01 PM   #2
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
No; swap pads
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 04-01-2023, 12:05 PM   #3
AK2112
AK2112's Avatar
Drives: 22 BRZ
Yeah they don't have the typical immediate grab that a lot of cars have. On winter tires especially, I have to get fairly deep into the pedal.
They do stop well on the street (have seen 60-0 tested at 104 feet) so I've just gotten used to it.
AK2112 is offline   Reply With Quote
Old 04-01-2023, 12:06 PM   #4
Rob2042
Thank you
Old 04-01-2023, 05:47 PM   #5
OldBiker
Drives: 2023 Gray BRZ
Many newer cars have over-boosted brakes... grab instantly. I am not a fan of this, as it makes heel-toe blipping touchy at normal speeds. I am very glad the BRZ has proper brakes.
OldBiker is offline   Reply With Quote
Old 04-02-2023, 01:44 AM   #6
Up4speed
Drives: 2023 BRZ Limited
The brakes are better that way, this way they are easier to modulate.
As long as the power is there when pushed harder, I like it better. As OldBiker said, also easier to heel & toe.
Up4speed is offline   Reply With Quote
Old 04-02-2023, 12:58 PM   #7
OkieSnuffBox
Drives: '23 BRZ Limited
Have you given them a good "break-in" cycle? Once I did that, like you would do with track brake pads, they felt much better.
When I ran Carbotech's, essentially 70-5 stops, constantly until the brakes smell and the pedal starts to get a bit soft. Let them cool completely, then ready to go.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 04-03-2023, 04:32 PM   #8
There is not.
You can get bigger bite/response pads, a stiffer caliper setup, or both.
Easy to do, relatively speaking.
Old 04-03-2023, 06:32 PM   #9
Rob2042
There is not.
Thank you
Old 04-04-2023, 12:37 PM   #10
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Is it really the actual performance of the brakes or just a system which has less boost and allows longer pedal travel?
Swapping out pads, calipers, and rotors would change some of the characteristics, but wouldn't you need to replace the power brake pump and maybe the brake lines if you want to make a real difference in pedal travel and earlier bite?
Desertnate is offline   Reply With Quote
Old 04-04-2023, 01:27 PM   #11
DarkSunrise
DarkSunrise's Avatar
The stock pads have poor initial bite, especially when cold. So you have to get fairly deep into the pedal travel before they grab. On the plus side, they are very progressive and easy to modulate even pushing hard on street tires.
I just changed to track pads and fluid, and they definitely bite harder and earlier in the pedal travel once bedded properly. But also a bit more difficult to modulate at the limit on street tires.
If I were you, for street use I’d swap to a pad that’s known for strong cold bite and bed them in well. Should give you that immediate response you want.
2022 BRZ Build
2013 FR-S Build
Old 04-05-2023, 09:04 AM   #12
BioRebel
Drives: Mini Cooper S
I found a "brake brace" helped to reduce pedal travel quite a bit with everything else being stock.
BioRebel is offline   Reply With Quote
Brakes, Brakes, and more Brakes Fish Eagle AFRICA 282 06-18-2019 04:36 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
STI hub and brakes on FRS JordanWho Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-16-2016 11:40 AM
Regarding brakes fito68 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-21-2015 03:15 PM
Will EVO 9 brakes fit? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-07-2014 05:13 AM
