Old 01-13-2016, 02:52 AM   #1
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
STI hub and brakes on FRS
Hey all.
This was discussed back in 2012 here but I want to revise the issue.
We recently ordered new wheels in 5x114.3 and want to get this conversion happening. I know at worst we can use conversion spacers but I have some proof that it's been done an done quite easily.
Some of you may know this car:
http://www.stancenation.com/2013/06/...ome-toyota-86/
I am close with the owner but unfortunately I don't speak Japanese, nor does he speak english. I was however, able to discuss all of this with his good friend and translator. This was the discussion.
If this is the case, it doesn't sound too troublesome. I wanted to know if anyone has done the conversion since the last post back in 2012.
I can get access to all the STI gear, I just need to know what I need. More importantly, if the STI hubs are a direct on to the FRS knuckle.
JordanWho is offline   Reply With Quote
Old 01-13-2016, 02:56 AM   #2
ryoma
ryoma's Avatar
from what I see in the last picture, it seems there is a spacer of some sort between the hub and wheel? could that be the stud conversion? I know that they sell something like that.
Old 01-13-2016, 03:07 AM   #3
JordanWho
JordanWho's Avatar
No, thats the rotor.
Old 01-13-2016, 03:10 AM   #4
ryoma
ryoma's Avatar
the rotor is the teal colored part. if you look closely, there is something like a spacer inbetween the rotor and rim. though, it might just be a spacer but I have seen a wheel stud conversion that looks like a spacer and gets placed between the rotor and rim. I forgot what the exact name for it was though...
Old 01-13-2016, 03:49 AM   #5
JordanWho
JordanWho's Avatar
There might be a spacer, but the conversation above is about the car in the picture. It's 100% 114.3 with STI brakes/hubs.
Old 01-13-2016, 11:01 AM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Just because he had the calipers doesn't mean he switched to the STI hubs, as they are a direct bolt on to the FRS hubs. Though The translator did say he switched. So in for more info.
Edit: Definitely looks like a conversion spacer.
DustinS is offline   Reply With Quote
Old 01-13-2016, 12:02 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
That definitely looks like a spacer of some type on there. There are many STI caliper kits available without swapping hubs.
Old 01-13-2016, 11:37 PM   #8
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
@JordanWho
wait...I thought you sold the 86
TylerLieberman is offline   Reply With Quote
Old 05-16-2016, 11:40 AM   #9
miguegd
Drives: Scion FRs MT 2015
Any updates ?
miguegd is offline   Reply With Quote
Brakes, Brakes, and more Brakes Fish Eagle AFRICA 282 06-18-2019 04:36 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
brakes vien Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-11-2015 12:48 AM
WRX brakes fit to 86/BRZ? Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-17-2013 02:11 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
