Old 03-30-2023, 12:00 PM   #1
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Whiteline KTA139A
Has anyone seen these yet or used them yet? What do you think?
Whiteline KTA139A
RT-BRZ is offline   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
RedReplicant (03-30-2023)
Old 03-30-2023, 01:00 PM   #2
RedReplicant
Drives: None
Looks like a decent option for those of us tied to classing where sphericals are extra points
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
RT-BRZ (03-30-2023)
Old 03-30-2023, 01:55 PM   #3
RT-BRZ
RT-BRZ's Avatar
Even more interesting is that you can get them for less than $350.
Old 03-30-2023, 04:34 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
These look like their original RLCA. Interesting
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-30-2023, 05:43 PM   #5
RT-BRZ
RT-BRZ's Avatar
It does appear that they just came back out with them. I guess they made these in the past huh? Weird.
Old 03-30-2023, 05:55 PM   #6
DarkPira7e
DarkPira7e's Avatar
Looking back, I guess they're different.
https://motoiq.com/project-autocross...d-whiteline/3/
They can be seen in this article
The Following User Says Thank You to DarkPira7e For This Useful Post:
RedReplicant (03-31-2023)
Old 03-30-2023, 08:07 PM   #7
RT-BRZ
RT-BRZ's Avatar
Ooohhhh....those were purdy.
I guess that's too much bling.
DarkPira7e (03-30-2023)
Old 03-31-2023, 11:26 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well I just ordered a set since I need to swap out my rear LCA's. Can't beat the price unless the joint is garbage, but there are fixes for that. 326 for the set with shipping. If anything they will just be a stopgap solution for me for now. I spent a lot of money on parts this year I didn't plan on buying
The Following User Says Thank You to NoHaveMSG For This Useful Post:
RT-BRZ (03-31-2023)
Old 03-31-2023, 11:43 AM   #9
Racecomp Engineering
Be very sure that the poly joint rotates easily and doesn't bind after installing. I've had an issue in the past on a different part.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
NoHaveMSG (03-31-2023), RT-BRZ (03-31-2023)
Old 03-31-2023, 11:46 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
- Andrew
Thanks, I will check it. I plan to pull it and measure it to see if I can find a spherical replacement anyway.
Racecomp Engineering (03-31-2023)
Old 03-31-2023, 01:18 PM   #11
RT-BRZ
RT-BRZ's Avatar
I also ordered a set. We'll see how it goes.
Old 03-31-2023, 05:57 PM   #12
RT-BRZ
RT-BRZ's Avatar
Steinjagr probably has the Heim joint ends that you would want. You would just need to fab up some bushings if you went that route. They also have poly ends as well.
https://steinjager.com/shop/products...&menu=category
NoHaveMSG (04-01-2023)
Old 03-31-2023, 07:49 PM   #13
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Spherical would be better for performance but how do they hold up to street usage ? What about NVH. Normally I stay away from spherical mounts but maybe I am wrong in my thinking.
I also hate poly bushings as well because once the grease is good everything just binds up lol.
autoracer86 is offline   Reply With Quote
Old 04-01-2023, 01:05 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My current LCA’s are on spherical’s already and they are the least of my nvh issues.
RT-BRZ (04-01-2023)
Whiteline IsaiahW Engine, Exhaust, Transmission 8 12-15-2021 06:38 PM
WTB: Whiteline LCA's Skurj Canada Classifieds 0 06-21-2017 06:11 PM
FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces e1_griego Brakes, Suspension, Chassis 1 02-15-2017 12:00 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit Quanye Brakes, Suspension, Chassis 7 02-07-2016 01:55 PM
