Drives: 2013 Subaru BRZ
Whiteline KTA139A
| The Following User Says Thank You to RT-BRZ For This Useful Post: | RedReplicant (03-30-2023) |
#2 |
Drives: None
Looks like a decent option for those of us tied to classing where sphericals are extra points
| The Following User Says Thank You to RedReplicant For This Useful Post: | RT-BRZ (03-30-2023) |
#3 |
#4 |
Rust bucket enthusiast
These look like their original RLCA. Interesting
#5 |
#6 | |
https://motoiq.com/project-autocross...d-whiteline/3/ They can be seen in this article
| The Following User Says Thank You to DarkPira7e For This Useful Post: | RedReplicant (03-31-2023) |
#7 | |
I guess that's too much bling. |
| The Following User Says Thank You to RT-BRZ For This Useful Post: | DarkPira7e (03-30-2023) |
#8 |
Drives: Crapcan
Well I just ordered a set since I need to swap out my rear LCA's. Can't beat the price unless the joint is garbage, but there are fixes for that. 326 for the set with shipping. If anything they will just be a stopgap solution for me for now. I spent a lot of money on parts this year I didn't plan on buying
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (03-31-2023) |
#9 |
Be very sure that the poly joint rotates easily and doesn't bind after installing. I've had an issue in the past on a different part.
- Andrew |
#10 |
Drives: Crapcan
Thanks, I will check it. I plan to pull it and measure it to see if I can find a spherical replacement anyway.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Racecomp Engineering (03-31-2023) |
#11 | |
| The Following User Says Thank You to RT-BRZ For This Useful Post: | NoHaveMSG (03-31-2023) |
#12 | |
https://steinjager.com/shop/products...&menu=category |
| The Following User Says Thank You to RT-BRZ For This Useful Post: | NoHaveMSG (04-01-2023) |
#13 | |
Drives: Toyota GT86
I also hate poly bushings as well because once the grease is good everything just binds up lol.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#14 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (04-01-2023) |
| Whiteline | IsaiahW | Engine, Exhaust, Transmission | 8 | 12-15-2021 06:38 PM |
| WTB: Whiteline LCA's | Skurj | Canada Classifieds | 0 | 06-21-2017 06:11 PM |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 12:00 PM |
| FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus | neilvosko | Brakes, Suspension, Chassis | 1 | 11-21-2016 02:44 PM |
| FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit | Quanye | Brakes, Suspension, Chassis | 7 | 02-07-2016 01:55 PM |
