Drives: 2013 Subaru brz limited
Whiteline
While doing the whiteline trans mounts i notice this! what could have caused this? Also, what could be done to prevent this?
![]() Sent from my iPhone using Tapatalk |
ProCrastinationConsultant
applying thread lock to the threads generally makes it harder for components to disassemble themselves.
friendly
Drives: 17' 86
imo this is a likely a defect, I'd contact whiteline.
Seek comfort in discomfort.
AutoX-10/10ths every run
You're not the first, or the last to have these fail in this way. They'll likely send you a new set, but I ended up going with the SPL units (https://www.counterspacegarage.com/s...s-brz-frs-gt86) after repeated failures on the WL units.
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Very typical for the Whiteline rear endlinks to snap as yours did. You can contact them for a replacement, or just get SPL and never think about them again.
#7 | |
Yeah SPL it is then! I just ordered some but ill still contact whiteline so i can have a “spare” laying around Sent from my iPhone using Tapatalk |
Drives: SWP BRZ
i should check mine lol
Drives: Crapcan
Rear?
Check the underside to make sure the tip of the sway bar is not contacting the underside of the body.
| WTB: Whiteline LCA's | Skurj | Canada Classifieds | 0 | 06-21-2017 06:11 PM |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 12:00 PM |
| FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus | neilvosko | Brakes, Suspension, Chassis | 1 | 11-21-2016 02:44 PM |
| FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit | Quanye | Brakes, Suspension, Chassis | 7 | 02-07-2016 01:55 PM |
