Old 03-29-2023, 09:37 PM   #1
redvee86
redvee
Drives: 2012 Sonic Blue 86 GTS AT
2012 vs 2020 steering feel difference
Hi all,
I recently upgraded from a 2012 auto GTS to a 2020 manual GTS and noticed the steering wheel feels lighter and more numb in the 2020 compared to the 2012 model. The 2012 model felt a more direct and had some real weight to the steering.
I have seen some commentary on here about this and some have suggested getting larger wheels and sticker tires to improve things, is that best way? The 2012 was stock standard but I upgraded to sticker Yokohama tires. The 2020 car is currently stock standard including the Michelin tires.
Thanks!
redvee86 is offline   Reply With Quote
Old 03-29-2023, 10:14 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
Adding caster also increases steering weight.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
redvee86 (03-29-2023)
Old 03-29-2023, 11:40 PM   #3
redvee86
redvee
Thanks! So based on what I have read about caster, I should add positive caster?
Old 03-30-2023, 03:18 AM   #4
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Tires play a large part of the steering feel as well.
My all year daily gets a wheel and tire swap for the winter/summer season.
The difference between the tire sets is immediate as the summers
are quite sticky and there is more feel and effort required.
Always amazed at the transformation in the driving qualities as well.
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
redvee86 (04-13-2023)
Old 03-30-2023, 12:29 PM   #5
RedReplicant
Drives: None
If it bothers you that much you can buy a different EPAS controller. I'm using this one https://www.nmstec.ca/product/psc/ with a speed to assist map that I set up with less assist than stock at speed but pumped up at pit/parking lot speed for max laziness.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 03-30-2023, 01:31 PM   #6
MJones_RB
MJones_RB's Avatar
One of the first mods I did on my 2013 FR-S was replace the steering wheel with an aftermarket one. For a stock steering wheel, it was actually fine. The aftermarket one had a more tactile feel, somewhat thicker and heavier, with a flat bottom that made getting out of the car easier.
MJones_RB is offline   Reply With Quote
Old 03-30-2023, 01:50 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
In addition to the above, caster is not the only alignment item that changes steering feel. For me, excessive toe (both in and out) makes the steering feel mushy and rubber-bandy. I experimented with different toe settings and like very minimal front toe out the best.
Ohio Enthusiast is offline   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
redvee86 (04-13-2023), strat61caster (03-30-2023)
Old 03-30-2023, 01:52 PM   #8
Ohio Enthusiast
Drives: 2018 BRZ
The facelift in 2017 made the steering wheel slightly smaller (14.5" to 14.25" in diameter) and more squishy to the touch. Some folks commented that it made it less tactile, echoing your comments about an aftermarket steering wheel.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
MJones_RB (03-31-2023)
Old 03-30-2023, 08:58 PM   #9
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
The bushings and soft parts (not the least of which includes tyres) get harder over time. Your 2012 would feel much "crisper" than a brand new 2012 - if that were possible.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
Old 03-31-2023, 01:20 AM   #10
strat61caster
strat61caster's Avatar
Check toe
ineedyourdiddly
Old 04-13-2023, 11:08 PM   #11
redvee86
redvee
Thanks All. One of the things I really liked about my 2012 86 was the steering wheel and steering feel. It always felt special getting behind it, especially after driving another car. It was just the right size for my hands and I loved the look of it with the 86 logo in the middle. The new one feels a bit small in my hands.
Strange steering feel speedyspaghetti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-13-2017 09:47 PM
Comfort + Steering Feel navanodd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-26-2017 10:57 PM
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 06:52 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 12:01 PM
