Old 03-15-2023, 03:06 AM   #1
mkootayy
Drives: 2013 subaru brz black
is RockAuto good- clutch & material?
Hello, I was looking to getting a new clutch because I'm experiencing a hard 1st-2nd gear shift, transmission has worn of course, but; I had found some parts on RockAuto parts, theres a clutch kit in mind for roughly $260 and one for $340, which is better?; Ceramic or Steelback? There's some cheaper ones for $150-$200 market, has me thinking, worth it huh? picking up other small items like TPMS sensors, alignment bolt & plate, shifter bushing. Just wanted more perspectives, let me know please what you all would think.
mkootayy is offline   Reply With Quote
Old 03-15-2023, 11:18 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just pay attention to the brand you are buying and the specifications. They sell all types of brands, so asking if "Rockauto" is good is really vague.
Like this kit is basically the stock clutch. Exedy makes our OEM clutches. They sell LuK, Exedy and Asin, all known good brands. They also show M-Pact but I don't know anything about them.
https://www.rockauto.com/en/moreinfo...GOyJKraOldbJeX
Old 03-15-2023, 12:39 PM   #3
RedReplicant
Drives: None
imo the best place to get the OEM Exedy is Autozone, they usually have a 20% + free shipping discount going.
https://www.autozone.com/drivetrain/...005/820584_0_0
Current code: MARCHSAVINGS
Price is like $215 plus tax right now, I've bought two of these kits from them in the last couple of years without a problem. I do buy an OEM Subaru TOB though, no idea if it is actually different or not.
RedReplicant is offline   Reply With Quote
Old 03-15-2023, 01:27 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Never mind sourcing parts, OP. Let's talk about how a stubborn 1-2 shift points to a bad clutch.
Unless something relevant has been left out of the story, I'm saying it doesn't.
Old 03-16-2023, 02:34 AM   #5
mkootayy
im gonna adjust the grab point, im thinking a bad bearing but its bearable (pun intended, not!) may bleed and fill the clutch fluid system too. I'll replace the throwout bearing, !!ADDED INFO downshifting to 5th I clutch in, out of 6th to neutral, put pressure against 5th then itll go in after a brief pause. otherwise it'll grind. I'm gonna re-replace the transmission oil to check for metal bits. transmission will whirr when cornering in some gears. realizing theres no point in checking for TOB Itll be replaced with clutch, pressure plate AND? flywheel and both bearings? I realize I should added more context in which parts in question sorry users. Trying to differentiate replacement of clutch vs transmission or find an order. Would there be an interest in replacing the shift bushing?
Also experiencing Vibration in the Transmission System pointing to a need to replace pressure plate?
Old 03-16-2023, 02:51 AM   #6
Ultramaroon
not playing cards
Ok. I think I understand. A few things seem to point to bad clutch. Makes sense.
aftermarket, budget, online store, quality, reviews
How to fix squeaky clutch for good cat94 Issues | Warranty | Recalls / TSB 15 09-16-2020 08:27 PM
RockAuto Closing out some BRZ & FRS Maintenance Parts Opie BRZ First-Gen (2012+) — General Topics 1 02-12-2020 04:43 PM
Exedy OEM Clutch Kit, TOB good quality? oldlostcory Engine, Exhaust, Transmission 9 09-01-2019 03:46 PM
Good books and Reading Material GotBRZ1691 Off-Topic Lounge [WARNING: NO POLITICS] 19 07-23-2014 02:01 PM
Used Good Condition - OEM clutch/flywheel/pressure plate (Off 2013 BRZ) Mujen84 Transmission and Driveline 0 05-05-2014 10:44 AM
