Old 08-21-2019, 11:15 AM   #1
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Exedy OEM Clutch Kit, TOB good quality?
I need to replace my TOB. I am going to replace my clutch while i'm down there. Does anyone know if the TOB in this kit is just as bad as the stock ones or is it better quality?
Is there any reason to replace the fork with this kit? I could pick up the verus one but if it's not needed then i'll pass. My clutch is creaking, think the grease around the clutch fork inside the housing has dried up.
Thanks for any help.
oldlostcory is offline   Reply With Quote
Old 08-21-2019, 11:21 AM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
There is no known aftermarket TOB, so the kit will have a stock one. Make sure it is the upgraded one with the white dot, if not go to the dealer and get one.
humfrz (08-21-2019), oldlostcory (08-21-2019)
Old 08-21-2019, 12:03 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The TOB was suppose to be getting updated to the new TOB with the white dot, but some remaining kits could still have the old design. If so then buy the new TOB. The fork upgrade is worth it, even for the OEM kit at stock power. Exedy’s Stage 1 kit is identical to the OEM kit, except it has a thicker/stronger pressure plate. Just saying.
Old 08-21-2019, 12:23 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I bought the same clutch kit and a new 2018 TOB from Subaru. The TOB in the kit was not the same bearing and looked to be an older revision.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (08-21-2019), oldlostcory (08-21-2019), Sportsguy83 (08-21-2019)
Old 08-21-2019, 12:42 PM   #5
oldlostcory
How's the clutch working out for you? Feel fine?
Old 08-21-2019, 12:54 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah so far so good. I did buy my car used with 19K miles on it. The clutch I pulled out at over 70K was the Excedy OEM and looked fine. I only changed it because the TOB was making noise. There was still plenty of meat on it, no glazing or abnormal wear.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 08-22-2019, 12:50 PM   #7
NV89
NV89's Avatar
Drives: 14 BRZ, Genesis coupe track, 05 sti
I have a hydraulic TOB is you are interested
Sent from my Pixel 3 using Tapatalk
NV89 is offline   Reply With Quote
Old 08-27-2019, 05:54 AM   #8
Skuggi
Drives: 13 brz man wrb
Fork´s a good idea
Previously had went to an upgraded clutch kit with more torque rating. Did NOT upgrade fork. Miles later the fork broke. Another garage dive. Don´t forget the grease as applicable.
Skuggi is offline   Reply With Quote
Old 08-27-2019, 12:00 PM   #9
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
If you're going to get the fork, you might as well get the pivot ball too.
Dr. BRZ is offline   Reply With Quote
Old 09-01-2019, 03:46 PM   #10
NV89
NV89's Avatar
Buy my hydraulic TOB
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 10:31 PM
Exedy OE replacement clutch. APEXIT53 Transmission and Driveline 2 04-08-2017 08:54 AM
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 10:36 AM
OEM Exedy clutch on backorder radroach Engine, Exhaust, Transmission 1 03-13-2015 11:30 AM
