Old 03-13-2023, 11:07 AM   #1
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
MAP sensor bolt spec
A few years ago I swapped my 2015 plastic intake manifold with the wrinkle red one from 2017+ and reused the original bolt. It wasnt an exact fit but kept the map sensor in place so I didnt fret over it. Now I am upgraded to a 4 bar and upping my boost so I want to get the correct bolt. See below for clarification
im sure I can pick something up at the hardware store just cant find measurements anywhere online
Ignore Your Doctor is offline   Reply With Quote
Old 03-13-2023, 12:38 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
My 2018 appears to use a coarse M5x15 flanged bolt with an un-threaded shoulder about 2.5 mm long at the base and an 8mm head. It doesn't look like the shoulder part is critical - it is narrower than the threads (vs. more typical shoulders where they are in the outer diameter of the thread) so couldn't be used for locating the bolt on the sensor.
Ohio Enthusiast is offline   Reply With Quote
OEM 14mm crash bolt torque spec? SmoothIsSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-09-2019 11:20 AM
Perrin/Mocal oil cooler - Torque spec for center bolt Clipdat Engine, Exhaust, Transmission 12 01-08-2019 01:57 PM
Crankshaft position sensor bolt size sfruski Engine, Exhaust, Transmission 0 09-01-2017 11:10 PM
Rear link bolt spec needed Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 10:21 PM
Camber bolt torque spec ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-09-2013 10:30 AM
