Old 07-07-2019, 11:00 PM   #1
SmoothIsSlow
OEM 14mm crash bolt torque spec?
Hi all!
I installed my SPC lower eccentric bolt today and moved the OEM lower bolt to the top strut hole.
I torqued the SPC bolt to 97 ft/lb per instruction. My understanding is that the OEM lower bolt is the OEM crash bolt for the top hole, as such, I torqued it do 114 ft/lb per this shop manual:
Was my understanding correct? Or does the top 14mm bolt now have to be torqued down more since it's in a larger diameter hole?
Thanks! Can't wait to get the car on track
SmoothIsSlow is offline   Reply With Quote
Old 07-07-2019, 11:07 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I say meet them in the middle.
It's torqued at lest.
Should be fine.
The Following User Says Thank You to Mr.ac For This Useful Post:
SmoothIsSlow (07-07-2019)
Old 07-07-2019, 11:09 PM   #3
SmoothIsSlow
Should be fine.
Thanks!
Meet them in the middle? According to the shop manual, both upper and lower bolts should be torqued to 114
Old 07-07-2019, 11:31 PM   #4
humfrz
Originally Posted by SmoothIsSlow View Post
Hi all!
I would say that they are both good-n-tight the way you tightened them down. Any more and I reckon the bolt/nut is going to come off in your hand/socket.
humfrz
Old 07-09-2019, 11:20 AM   #5
wparsons
wparsons's Avatar
Torque spec is for bolt stretch and clamping force, the diameter of the hole doesn't matter.
What you will want to do is loosen both bolts with the weight of the car on the wheels, that'll settle the car to max negative camber. If you need to dial it back at all, do that with the lobed bolts in the bottom holes (also with the weight of the car on the wheels).
flickr
Perrin/Mocal oil cooler - Torque spec for center bolt Clipdat Engine, Exhaust, Transmission 12 01-08-2019 01:57 PM
Nuts for Subaru 14mm Crash Bolts smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-10-2016 12:44 AM
FS: 14mm camber (crash) bolt frslee Brakes, Suspension, Chassis 1 05-06-2015 10:32 AM
WARNING: DO NOT use 14mm OEM camber bolt in slotted hole switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 10-31-2014 03:56 PM
Camber bolt torque spec ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-09-2013 10:30 AM
