Old 03-08-2023, 02:13 PM   #1
chriskep1
Drives: frs
Steering wheel angle sensor
Hi
I had to replace a front lower control arm and also the steering wheel airbag. I've since repaired all. I now get a code 1231 steering wheel angle sensor abnormal. I replaced the said sensor but still get the same code. I am wondering if there is a way to test the actual sensor itself with a meter and would a need to calibrate the the steering wheel position cause that fault. It reads 0 voltage. I checked the harness and get proper voltage at pins 1 to 4 and there is negligible resistance between pin 1 and the chassis. Thanks in advance for any help/advice.
chriskep1 is offline   Reply With Quote
Old 03-08-2023, 09:26 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
Techstream (the dealer software) is needed to calibrate the sensor. It also has test functions to check sensor output.
The only way to perform the calibration is with the software.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
strat61caster (03-09-2023)
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 09:13 AM
Steering angle sensor is failing. Enrgkid Issues | Warranty | Recalls / TSB 1 02-01-2021 08:00 PM
DTC 1231 Steering Angle Sensor Irace86.2.0 Issues | Warranty | Recalls / TSB 1 11-27-2019 09:34 PM
Steering angle sensor reset Brzxton Electronics | Audio | NAV | Infotainment 3 08-16-2019 01:40 PM
Can anyone help me out with a Techstream steering angle sensor reset? norcalpb Northern California 4 08-15-2019 06:02 PM
