Northern California NorCal
Old 08-14-2019, 01:34 PM   #1
norcalpb
norcalpb's Avatar
Can anyone help me out with a Techstream steering angle sensor reset?
I am located in San Ramon and don’t have the cable and software...would anyone be willing to assist me with this? I’d pay $20.
Thanks,
Steve
Old 08-14-2019, 02:53 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Does resetting the ECU not reset the sensor?
BigTuna is offline   Reply With Quote
Old 08-14-2019, 05:53 PM   #3
norcalpb
norcalpb's Avatar
Like unplugging the negative terminal from the battery, letting it sit and then plugging it back in?
Old 08-15-2019, 03:50 PM   #4
BigTuna
BigTuna's Avatar
That's what I was referring to. I just know the TPS gets reset when you do that, so it might be worth a shot.
Old 08-15-2019, 06:02 PM   #5
norcalpb
norcalpb's Avatar
The car ended up needing an entire alignment so I’m good now.
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 09:13 AM
Steering angle sensor reset Brzxton Electronics | Audio | NAV | Infotainment 3 08-16-2019 01:40 PM
Anyone local with a tech stream that could help? Steering angle sensor issue derrickgoes Southern California 2 06-18-2018 11:05 PM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 06:28 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
