Old 03-05-2023, 06:09 PM   #1
Jmk91
Drives: 2017 Brz Performance Package
Bilstein B14/B16 PSS10 coilovers
Bilstein B14/B16 PSS10 coilovers with HVT camber Plates and Rear Raceseng top mounts. Around 5k miles on set up, coilovers are in mint shape and work as should. 1000 shipped USA! Coilovers are packaged and ready to ship!
Jmk91 is offline
Old 03-07-2023, 06:47 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I literally just bought these lol. Mind telling me how was the installation process? How much is the drop with factory settings? Did you require camber bolts and RLCAs?
spcmafia is offline
Old 03-07-2023, 11:04 AM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
I have a set of these in a box right now. They were taken off my old car which also used Raceseng CasCam plates. Would it be helpful to share a picture of my car with them installed so you can see the ride height? I could then go count the threads showing on them.
Pat is offline
The Following User Says Thank You to Pat For This Useful Post:
spcmafia (03-07-2023)
Old 03-07-2023, 11:45 AM   #4
spcmafia
spcmafia's Avatar
It would absolutely help, thank you. Did you install the camcam plates at the same time with the coilovers or was it an incorporation later on. So far I've found one video installation on a BRZ and it looks like the poster used all OEM equipment. I've read in different post that the overall drop is about 1-1.5 in which technically should be okay with alignment. Just want to cover my bases before ordering camber bolts and RLCAs.
spcmafia is offline
Old 03-07-2023, 01:08 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
I installed the CasCam plates at the same time.
What size wheels will you be using?
What ride height are you going for? Mine was 1 to 1.5" lower than stock I think.
Pat is offline
Old 03-07-2023, 01:31 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
These wheels are ARC-8s 17x9 ET35. Camber in the picture is probably about 2.2* all around.
And here are the spring perch settings from that picture:
If you want more pictures, check out https://rockymountain86.com/ and look for car #979
Oh, and I had OEM mounts in the rear.
Pat is offline
The Following 3 Users Say Thank You to Pat For This Useful Post:
Jmk91 (03-08-2023), spcmafia (03-07-2023), strat61caster (03-08-2023)
Old 03-08-2023, 07:06 PM   #7
Jmk91
You can totally return them and buy mine! You’d definitely save a few dollars doing so too! Food for thought!
Jmk91 is offline
Old 03-21-2023, 02:20 AM   #8
Jmk91
Sold close
Jmk91 is offline
Bilstein Coilovers Dogster70 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-29-2017 11:12 AM
New Bilstein PSS B14 Coilovers Dan37BRZ Brakes, Suspension, Chassis 2 02-23-2017 01:30 PM
Bilstein B14 PSS Coilovers go_a_way1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-30-2015 05:03 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
>>>Bilstein B16/PSS10 Coilover - US Release<<< FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 12-20-2013 12:47 AM
