Drives: 2013 Scion Frs Whiteout
Bilstein Coilovers
So I ordered these coils and when they arrived I realized they were without camber plates, reading up on it they said you can use your oem camber plates from your stock set of coils. So my questions are: can you actually use your oem equipment on these aftermarket coils? (I’m not really looking for more camber anyway I just want them to be able to go on seeing as I have camber bolts already) and can anyone actually inform me on how to attach the oem ones to my bilsteins? (I’ve done coils before but never had to mess with any camber plating or spring compressing). Thanks a bunch in advance guys!
Yes you reuse the OEM top hats. Unless you have aftermarket camber plates. No oe camber plates exist.
The instructions on the Bilstein website should help you figure it out. I'm on my phone so I can't grab a link right now but find the product page for this car and your dampers and there should be a downloadable PDF to set you straight if the included instructions are the older set that isn't very detailed. |
Drives: 2014 GT86
And unless you Must Have more camber then can be dialed w. camberbolts (but that's usually need for someone doing trackdays a lot, in which case i guess that you would have chosen a bit more track-oriented coilovers), you are better off using OEM topmounts anyway, NVH/comfort wise, so nothing wrong with reusing them, mostly gains.
| The Following User Says Thank You to churchx For This Useful Post: | wparsons (12-27-2017) |
Bilstein product page:
https://us.bilstein.com/en/product-s...91417624293786 Direct link to latest pdf installation instructions: https://productdeskapi.cart.bilstein...M4-Y666A00.pdf |
I'd suggest getting new OEM ones, but if you have low mileage on the original ones you might be ok.
Drives: 2014 BRZ
Im running Bilstein b14.. i just used the oem top hats and have camber bolts for camber
Drives: DGM BRZ Prem AT
| Tags |
| bilstein coilovers frs, bilsteins, coilover suspension, frs suspension |
| TX:FS: Bilstein B14 Coilovers | Darhk | Brakes, Suspension, Chassis | 1 | 10-18-2017 06:03 PM |
| New Bilstein PSS B14 Coilovers | Dan37BRZ | Brakes, Suspension, Chassis | 2 | 02-23-2017 01:30 PM |
| FS: Bilstein B14 PSS coilovers | Kerune | Brakes, Suspension, Chassis | 12 | 09-04-2015 01:49 PM |
| Anyone ETA on Bilstein coilovers? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 01-31-2014 11:26 AM |
| AJ USA Inc FRS/BRZ Bilstein Coilovers are here! | AJUSA.com | Brakes, Suspension, Chassis | 11 | 12-06-2013 01:58 PM |
