Old 02-06-2023, 09:15 AM   #1
baofrs
baofrs's Avatar
Drives: 2014 Scion Frs
I can smell my exhaust fumes through my ac.
I have been dealing with this issue for more than a year now. When the ac is on and my car is just idling (windows up) I can smell every bit of my catless fumes coming through the ac. This applies to all my ac settings but whenever I have the recirculation on, the smell goes away. Also I forgot to mention that my cold air went out about a year ago aswell, not sure if this would have to do anything with the smells I'm facing. Has anyone else dealt with this issue? And if you have what did you do to diagnose/fix. Hopefully I haven't been breathing in carbon monoxide everyday for the past year.
Gruppe-S UEL catless headers
1320 dual resonated catless fp
Greddy rs single exit catback
baofrs is offline   Reply With Quote
Old 02-06-2023, 09:34 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I would start by checking for exhaust leaks.
I ditched my catless front pipe due to fumes. Smell was an issue more often than not.
Old 02-06-2023, 09:42 AM   #3
baofrs
baofrs's Avatar
Were you getting fumes from your ac aswell? After I installed the front pipe the smell definitely get worse.
Old 02-06-2023, 07:09 PM   #4
Grady
Grady's Avatar
Catless setup smells.
I would still check for header leaks in the engine bay.
And yes you have been breathing in CO. As long as the PPM is low and exposure time is low you will be fine.
Old 02-06-2023, 07:19 PM   #5
Teseo
Drives: frs
No OEM cats, will smell awful
The Following User Says Thank You to Teseo For This Useful Post:
x808drifter (02-09-2023)
Old 02-07-2023, 07:48 AM   #6
Grady
Grady's Avatar
But catless and E85 smells great!
The Following User Says Thank You to Grady For This Useful Post:
Old 02-07-2023, 09:49 AM   #7
RToyo86
RToyo86's Avatar
On occasion the smell would get into the cabin with all of the windows up. Was worse with rear seats down which lead me to believe it was coming in via vent holes in the trunk.
It was hard to keep track of, any time I cracked the windows fumes were sucked into the cabin. Both windows all the way down was far less noticeable.
Old 02-07-2023, 11:40 AM   #8
Teseo
Drives: frs
But the craves of French fries...
Old 02-07-2023, 11:48 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Also I forgot to mention that my cold air went out about a year ago...
What?
Old 02-09-2023, 03:05 AM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Answered your question right there.
And no. The "CAI" will have nothing to do with it.
The Following User Says Thank You to x808drifter For This Useful Post:
Teseo (02-09-2023)
air condition, carbon, catless, fumes, leak
Exhaust smell after header install Jmk91 Engine, Exhaust, Transmission 71 03-28-2021 04:56 PM
Catless header exhaust smell? Aegis3425 Engine, Exhaust, Transmission 18 03-18-2020 07:01 PM
Exhaust Smell Jspark Forced Induction 5 03-15-2019 12:44 PM
Exhaust Fumes/Smell Question/Opinions Mr.Impreza Engine, Exhaust, Transmission 5 05-19-2016 09:57 AM
oil smell from exhaust..catless? nickmerronesucks Engine, Exhaust, Transmission 7 07-22-2015 05:44 PM
