Old 07-22-2015, 08:22 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
oil smell from exhaust..catless?
This is not a cam plate leak.
Ever since ive gone catless i smell the catless smell and some oil from exhaust occassionally...is this oil smell a concern or normal with our cars catless?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 07-22-2015, 08:43 AM   #2
celek
Resident Gear Head
celek's Avatar
might be a coating on the new pipe burning off. How long has it been on?
Brand?
celek is offline   Reply With Quote
Old 07-22-2015, 09:20 AM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I noticed this too when I went catless. No problems so far and no oil consumed by the engine. I think its just one of the joys of being catless.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-22-2015, 10:21 AM   #4
ramiram1984
Drives: 2016 STi DGM
It's cuz you're careless and you'll notice is more when you're at a stop light. Or you can also have an exhaust leak down there and you don't know about it...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 07-22-2015, 11:41 AM   #5
nickmerronesucks
Ned flanders
I do have an exhaust leak at the over pipe but not worrying about it until i install my turbo kit. just wanted to make sure this was OK. Not new materials burning off. No noticeable oil consumption As Takumi788 stated. so im gonna write this off as okay
797Performance.com
Old 07-22-2015, 11:46 AM   #6
ramiram1984
Woops, meant you're catless...
-2014 SSM BRZ MT
Old 07-22-2015, 01:17 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Careless/catless, same difference. I mean, I don't want my grandkids to be able to breathe...
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-22-2015, 05:44 PM   #8
steve99
exhaust leaks not only let exhaust gas out they often "suck" fresh air in between exhaust pulses, usually at idle and lower rpm on\off throttle
as your leak is near 02 sensors it can effect 02 reading as it sees fresh air with high 02 content so signals ecu to add fuel to engine as it thinks its lean, but your going to run rich due the unneeded fuel hence the fuel smell
log your long term fuel trims and commanded afr verses afr.
Catless header exhaust smell? Aegis3425 Engine, Exhaust, Transmission 18 03-18-2020 07:01 PM
Running catless, rasp and smell pgeist Engine, Exhaust, Transmission 41 04-21-2014 07:26 AM
FS: Invidia Catless exhaust set Jchonn Engine, Exhaust, Bolt-Ons 11 04-08-2014 09:55 AM
Invidia N1 sweet smell from exhaust jonbonazza Engine, Exhaust, Transmission 15 12-26-2013 01:18 PM
