Old 01-12-2023, 03:18 PM   #1
DC2R
Drives: 2014 Scion FR-S
Which Motul oil to use?
Hi all, question about engine oil. What is the difference between the different Motul 8100 oil types. Which one should I be using? Previously I used Motul 8100 Eco-lite 0w20. I live in Miami and want to try 5w30 with the hotter climate down here. Good idea?
I'm stock besides catless uel header and E85 OFT tune. Most all my commuting is very short trips. I will also be adding LiquiMoly MoS2 Anti friction Treatment. The types Amazon has are below. Any recommendation would be appreciated. Thanks!
Eco-energy.
Exo-lite.
X-clean efe c2/c3.
X-clean + c3
DC2R is offline   Reply With Quote
Old 01-12-2023, 07:03 PM   #2
The weight is more important than anything else. The formulations are for different standards.
If you want the best protection, just use 300V. It's straight up more durable with more additive.
Tatsu333 (01-27-2023), x808drifter (01-13-2023)
Old 01-24-2023, 04:23 PM   #3
ThatYeti
So the 300V in 0w20 then? Needing to do a fluid change on mine and I was running thicker oil at your suggestion before I had an oil cooler installed, but thinking I can go back to 0w20 now that I've got it. Right? (car is road driven sparingly (weekend trips) and 3-5 track days a year, open to any options)
ThatYeti is offline   Reply With Quote
Old 01-24-2023, 05:18 PM   #4
Watch your oil temps. If you're still on the warmer side with the cooler, on track, use the 30 weight.
It'll largely depend on your driving habits and ambient conditions.
Second gen cars should be 30 weight universally, IMO.
Tatsu333 (01-27-2023), x808drifter (01-26-2023)
Old 01-24-2023, 06:06 PM   #5
ThatYeti
Never had an issue with temps, even running 5w30 w/o a cooler on the track.
First gen car ('17) with low miles (20K) so I should run 0w20? or 5w30? Probably sees 2k of street driving a year (spring/summer/fall) but nothing that would have me worried about temps.
Old 01-24-2023, 11:18 PM   #6
If your temps are in line, then use the factory recommendation of 0W20.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Tatsu333 (01-27-2023), ThatYeti (01-25-2023), x808drifter (01-26-2023)
Old 01-25-2023, 09:21 AM   #7
ThatYeti
Thanks, and definitely stick with 300V? Or other options that work too?
Old 01-25-2023, 02:31 PM   #8
KillerBMotorsport
KillerBMotorsport's Avatar
<--- this guy uses the High RPM 300V 0w-20 and the oil analysis results have been good so far.
KillerBMotorsport is offline   Reply With Quote
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post:
Bonburner (01-30-2023), Tatsu333 (01-27-2023), ThatYeti (01-25-2023), x808drifter (01-26-2023)
Old 01-25-2023, 04:32 PM   #9
I use Motul 300V.
Old 06-11-2024, 05:43 AM   #10
Seb99
Drives: GT86
Thank you Mike. Your knowledge is appreciated.
Could you please explain what are the technical reasons that you universally recommend 30 weight for the second gen cars (compared to first gen)?
Seb99 is offline   Reply With Quote
Motul 300 LS 54fighting Engine, Exhaust, Transmission 2 11-19-2020 06:22 AM
Motul coolant leevanf Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-25-2018 03:38 PM
Motul 8100 Eco Lite vs Motul 300V vs Eneos Sustina Lust Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 08-28-2017 08:10 PM
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 11:51 PM
motul Oil whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-24-2013 11:12 AM
