Drives: 2014 BRZ Limited A/T
Motul coolant
Hi Guys,
I understand the oem coolant should be good for nearly 11 years. I flushed mine out and used motul coolant instead, then just top off the reservoir with distilled water. How long/often should i flush and replace coolant with the motul? Its purple stuff. |
#2 | |
![]() The topping off with distilled water part is OK. HOWEVER, if it were my car, and someone put that stuff in my car, I would either: Carefully read the ingredients listed on the MSDS ......and compare with the ingredients listed on the OEM coolant ....... OR Drain that stuff out, flush the system and refill with the OEM recommended coolant. humfrz |
| How is it possible to lose coolant, if the coolant system in a car is a closed loop, | ghostzfh | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-12-2020 01:09 AM |
| FS: Motul engine oil, brake fluid, coolant and gear oil | Jesse0923 | Mechanical Maintenance and Tools | 7 | 09-07-2019 10:05 AM |
| Motul 8100 Eco Lite vs Motul 300V vs Eneos Sustina | Lust | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 58 | 08-28-2017 07:10 PM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
