Old 08-21-2012, 02:03 PM   #1
bladesamurai
Drives: 13 BRZ, 04 SV650
CS Legal Wheel
I'm new to autocross but I'm perusing different stores to see what sort of options there are if I wanted to get a second set of wheels for my summer tires. From what I've read I need to keep the stock size/width, and also keep relatively close to the original offset of the wheels. That said, does that mean something like this would work?
http://www.machiii.net/index.php/whe...t-version.html
They'd be a bit lighter than the stock wheels and hopefully let me stay in the stock class. The only question is if there's some additional rule that I'm overlooking that would make these wheels bump me up or something.
Thanks!
bladesamurai is offline   Reply With Quote
Old 08-21-2012, 02:16 PM   #2
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Ya these would work they look nice. You can go from a 17x7 +48 to a 17x7 +42 to help widen the track of the car just a tad.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-21-2012, 02:30 PM   #3
simpleisbest
Senior Citizen
Drives: Scion FR-S
How much does the 6mm wider offset really effect performance?
I have read talk that narrower is better for slaloms, but since 6mm wider isn't even flush with the body, would it really make the car "wider"?
What are the real world benefits are there to a 6mm wider offset?
Fit wider tires, maybe?
simpleisbest is offline   Reply With Quote
Old 08-21-2012, 02:50 PM   #4
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Narrower overall is better for the reason of total track width squeezing through features. The reason for 6mm more would be tire clearance to the front struts. I believe 42mm offset with 225-235mm tires shouldn't really extend past the bodywork considering the rear is wider. So the +42 is a good idea if you are running 245 or bigger tires, but for most the +48 I would guess is fine.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-21-2012, 05:58 PM   #5
xwd
The 5zigen FN01R-C was one of the wheels I was looking at when looking for stock class wheels but I wasn't sure if 245 Hoosiers would fit with the +48 rim. I had friends that ran them years ago and always liked them. Can't beat the price either.
From my test fitting I do think a 245 Hoosier would fit in the front even with a +48 rim. It's going to be really close but I think it would fit and if it didn't a 3mm spacer would probably work. With a +42 rim and a 245/40/17 Hoosier A6 there is probably a little under 1/2" between the tire and the front spring perch. 6mm is less than 1/4".
With a +42 rim the 245 Hoosiers still fit within the front fender.
Old 08-21-2012, 08:18 PM   #6
simpleisbest
Senior Citizen
Drives: Scion FR-S
Noob stock class question here:
Is there any benefit (performance wise) to staying with the narrower offset (tire track narrower than body width)? No matter how narrow the tire track is, the body of the car still has to navigate the cones, right?
Other than that, I imagine that a wider offset would negatively effect turn-in response (a bit), but add more transition and steady state stability, right?
So I guess you would ideally want to go wide enough to not effect overall vehicle width, correct?
Old 08-21-2012, 08:29 PM   #7
ABQautoxer
ABQautoxer's Avatar
6mm really isn't going to change much of anything. As long as you aren't wider than the body, like you said which can hit cones too.
TomR
Old 08-22-2012, 10:53 AM   #8
Biggins
Drives: Yes
Are they any lighter used or OEM Subaru options out there?
I'm waiting on the Enkeis to become available, but I wouldn't mind having a spare set.
Biggins is offline   Reply With Quote
Old 08-22-2012, 11:03 AM   #9
ABQautoxer
ABQautoxer's Avatar
There are a couple that are lighter than stock but the offset is +50. I'm waiting for the RPF1 in 17x7 +42 for $219ea in to be released in October before I decided.
TomR
Old 08-22-2012, 11:58 AM   #10
edj
edj's Avatar
Drives: 2022 Toyota GR86
i'm using the Koesei wheels with the +50 offset and 1/4" spacers in the front.
the Hoosier 245 A6 tires without the spacers were just a little too close to the struts
for my liking.
if i get the RPF1 wheels i may also need to get longer wheel studs as the extra 2mm
offset may not allow for enough thread contact to keep the nuts secure.
edj is offline   Reply With Quote
Old 08-22-2012, 12:00 PM   #11
ABQautoxer
ABQautoxer's Avatar
You should not need longer studs. It should have the hub of the wheel machined so that isn't necessary as it is with other wheels.
TomR
Old 08-22-2012, 12:43 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
I'm looking at the same wheel! I heard from a friend that the newer productions of RPF1 are supposed to be more rigid as well. Supposedly they did a quiet design upgrade, but it only applies to newer sizes and production lots...
The Tire Rack RPF1 in 17x7 +42 seems to be the best available "bang for buck" wheel I've found so far.
Old 08-22-2012, 01:33 PM   #13
Biggins
Drives: Yes
That is my plan right now, but I'd be open to something from Team Dynamics, 949 Racing, or anything else.
I was looking at older 17x7 OZ Superleggeras from early WRXs that might work with (or without) hubcentric rings, though the offset was still +48.
Old 08-22-2012, 01:54 PM   #14
simpleisbest
Senior Citizen
Drives: Scion FR-S
Man I wish 949 would come out with a Stock class legal wheel.
I love their dual valve set-up!! Don't ever see it happening though...
Wheels - What is legal? JDMSushi AUSTRALIA 86 12-26-2014 05:44 AM
Will sound tube delete be legal? celica73 Tracking / Autocross / HPDE / Drifting 7 08-17-2012 06:18 PM
Legal exhaust setups? kharn83 AUSTRALIA 5 08-03-2012 01:11 AM
[FYI] Street Legal Info Calidrifter Southern California 7 06-29-2012 02:02 PM
Max legal interest rate? UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 40 03-12-2012 01:50 PM
