Old 08-17-2012, 03:53 PM   #1
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Will sound tube delete be legal?
For ST classes. I know the intake can be replaced, but is the sound tube part of the intake? Will all the plumbing need to be left in place, even if it's non-functional? Will it be legal to make the sound tube non-functional?
Yes it would be a weenie protest.
Scott
celica73 is offline   Reply With Quote
Old 08-17-2012, 04:18 PM   #2
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Who knows with ST's screwy rules.... Best suggestion: sebscca.com Drop a note and get an official opinion from the STAC and/or SEB.
I would assume that the sound tube is fine to remove since it does nothing but transmit noise... but I've seen stranger things happen.
Sam Strano is offline   Reply With Quote
Old 08-17-2012, 04:40 PM   #3
xwd
It's part of the intake, so you can remove it. It doesn't attach to anything other than the intake.
Old 08-17-2012, 04:48 PM   #4
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Like Sam said, weird stuff happens so the letter is best but I would assume yes. One thing you could check is if the 302 Mustang guys deleted it (Terry Fair for one, before he moved to ESP) as they have the same type of device on the intake of the new Mustangs.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-17-2012, 05:08 PM   #5
Mitch
form follows function
Drives: RIP '13 BRZ
14.10.C: The air intake system up to, but not including, the engine inlet may be modified or replaced. The engine inlet is the throttle body, carburetor, compressor inlet, or intake manifold, whichever comes first. The existing structure of the car may not be modified for the passage of ducting from the air cleaner to the engine inlet. Holes may be drilled for mounting. Emissions or engine management components in the air intake system, such as a PCV valve, or mass airflow sensor, may not be removed, modified, or replaced, and must retain their original function along the flow path.
Seems okay by the rules. Of course straight-forward rules have picked up skewed interpretations in the past.
Mitch is offline   Reply With Quote
Old 08-17-2012, 05:50 PM   #6
Steve35
Drives: Scion
I might depend on what Scion/Subaru officially calls that part. The MX5 STR guys tried to take something off when installing their intakes. The SEB said no, because Mazda called that part something other than an "intake" part.
There was a long thread over at the Miata.net forums about it. I with I could find it.
Steve
Steve35 is offline   Reply With Quote
Old 08-17-2012, 05:59 PM   #7
blkwrxwag
Drives: DS FRS
On the MX5, it wasn't part of the intake. It was a radiator cooling duct, that you needed to remove in order to install the Mazdaspeed/AEM intake.
I see no problem with the sound tube thingy removal.
blkwrxwag is offline   Reply With Quote
Old 08-17-2012, 06:18 PM   #8
Steve35
Drives: Scion
Nor do I, but it is the SEB you're dealing with.... sic
Steve
Why delete the sound tube? feldy Engine, Exhaust, Transmission 77 04-05-2021 11:12 PM
Dynosty FR-S/BRZ Sound Tube Delete Kit Dustin@Dynosty Engine, Exhaust, Bolt-Ons 104 02-11-2014 10:35 AM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
The intake sound tube MrVito Scion FR-S / Toyota 86 GT86 General Forum 8 12-09-2011 07:32 PM
Sound induction tube Yay, or ay? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 22 12-04-2011 09:30 PM
