Old 01-03-2023, 04:47 PM   #1
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
Is alternator output load dependant ???
As I was driving around town, I noticed the voltmeter reading on the dash, is swinging between, 12.4 volts and 14.3 volts. Seems strange as I am used to voltage staying constant all the time around 14.3 in other cars. I get home and let the car idle, check battery voltage with a hand held voltmeter and the readings agree with the in dash meter. So I start turning appliances on and off, lights, brake lights, heater headlights all with the engine idling. The results are when there is no load or minimal load is being applied, the voltage drops to battery voltage of 12.6. When I turn on some load, the voltage increases to 14.3 and stays there until the load is removed, then the voltage again drops down to battery voltage. It appears to me that the alternator output is somehow correlated to the load on the system. It’s as if the alternator knows that the battery is fully charged and does not need to output a higher charging voltage. This may be designed in, to remove some mechanical load for purposes of decreasing fuel consumption. I have no problem whatsoever with the battery going dead. Does this sound normal? Has anyone else noticed this behavior?
Mcgiiver is offline   Reply With Quote
Old 01-03-2023, 05:20 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Yes. The ECU will regulate the alternator output. You can even see it go up and down while cruising.
dragoontwo is offline   Reply With Quote
Old 01-03-2023, 05:25 PM   #3
Mcgiiver
Yes, I saw it varying while cruising, that is what scared me.
Old 01-03-2023, 08:31 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Shouldn't be issue of any sort, with exception of maybe using some 12V>A/C transformator (to eg. power laptop), some models of which due such variances may stop charging. Never had problems with car itself or mobile gadgets charged with 12V cigplug > usb adapters.
Old 01-03-2023, 08:39 PM   #5
Grady
Grady's Avatar
It is smart charging for AGM batteries. It looks at battery amps/temperature to determine if a fast charge is needed. A large system load will not discharge the battery.
Old 01-04-2023, 08:17 AM   #6
Assuming they still use the updated system from '17.
It would be concerning if it DIDN'T fluctuate.
Old 01-04-2023, 11:58 AM   #7
WNDSRFR
Drives: FR-S,GTI
Aren't all alternators load dependent? Always have been. In the old days they used a voltage regulator. Now a days I think the ECU controls everything.
Old 01-04-2023, 01:20 PM   #8
The beauty of the ECU is that the alternator can be sort of fine tuned as to exactly when it does and does not charge. The regulator could say "to much" or "to little" and switch the charging on or off but that was about it.
Old 01-04-2023, 02:20 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I had no idea they changed this. Very cool, learned something today Thank you for posting this
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-04-2023, 02:40 PM   #10
All the facelift changes are here:
Old 01-04-2023, 03:38 PM   #11
dragoontwo
dragoontwo's Avatar
It's the same. Page 138 of a PDF I can't seem to upload. It's not above the PDF limit.
Old 01-04-2023, 05:20 PM   #12
Figured that the upgrade will still apply.
Upload the PDF as an image using the "insert image" icon above the text box.
Old 01-04-2023, 05:37 PM   #13
dragoontwo
dragoontwo's Avatar
Tried that. Keep getting notification about missing security token.
Old 01-04-2023, 06:41 PM   #14
Odd. I get the same with it. First for me.
High Output Alternator Ace23_BRZ BRZ First-Gen (2012+) — General Topics 19 12-04-2022 07:09 AM
Adjusting AFR with Engine Load Compensation (instead of Load Limits) Tor Software Tuning 33 08-17-2021 08:58 AM
High Output Alternator bear89103 Electronics | Audio | NAV | Infotainment 12 06-09-2017 03:37 PM
Output shaft bearing mhiscott Engine, Exhaust, Transmission 10 08-09-2016 06:04 PM
power output oft tunes denso Software Tuning 3 09-15-2015 06:53 AM
