| Member's Car Journals Car journals by our members. |
FT86Club Official Vendor
Drives: 2023 BRZ
Ansix Auto's 2023 WRB BRZ Streetable Track Build
Here's the car, all stock from a the Kelowna Subaru. We drove 4 hours to pick it up. Just 13kms on the odometer.
![]() ![]() We've already done quite a bit to the car but we'll post updates regularly but it may not be in chronological order. We'll have lots of images documenting what we've pulled out the car and how much everything weighs. Stay tuned!
Drives: 2023 BRZ
Here's our first quick DIY mod.
For those of you using a Racebox Mini for lap timing, here's a good way to mount it where it's clean and allows the Racebox to have a good line of sight for the GPS satellites. We just hot glued in four 10mm x 3mm neodymium magnets to the back of the tie down cover. The Racebox just snap in when you want it there and looks OEM when it's not there. ![]() ![]() ![]()
Drives: 2023 BRZ
First up, some weight savings. Antigravity ATX30RS battery installed with a custom CF tie down. 28lbs saved.
Weights: Stock Battery - 34lbs / 15.4kg Antigravity ATX30RS - 6lbs / 2.7 kg Stock battery tie down - 0.27lbs / 122g Custom CF tie down - 0.08lbs / 38g ![]() ![]() ![]() ![]()
Drives: 2023 BRZ
We tested the car on track and we kept accidentally hitting the voice command button. So we went ahead and did a voice command delete mod. We purchased a wheel from a first gen which didn't have the button and swapped the guts. While we had the steering wheel apart, we removed the weight inside as well. Saved 289.6g / 0.64lbs.
Drives: 2023 BRZ
Bye Bye fake sounds. Removed the control unit along with the speaker behind the head unit.
-688g / -1.5lbs ![]() ![]() Installed the Perrin crank pulley. Wasn't as light as we'd hoped. -468g / -1.0lbs ![]()
Drives: 2023 BRZ
I was wondering how much weight it would save to remove the control unit and speaker. Bummer it's not more. But I appreciate you guys documenting it.
Director of Rocky Mountain 86CUP
Drives: 2023 BRZ
We installed an off the shelf axle back exhaust. The tips were touching the bumper so we had to weld on pipe to replace the tip. Picture shows the weight with the tips still on.
-5.44kg / -12lbs ![]() ![]() ![]() We also installed rear upper control arms to dial in the camber. They happened to drop some weight too. -2.9kg / -6.4lbs ![]()
Drives: 2018 BRZ
It adds up!
Rust bucket enthusiast
This is too true. I recently weighed my turbo FRS and was surprised that it was near 2650lbs, far lower than I had thought. It took me a long while to realize how many little things I've removed/changed and how much it's removed cumulatively.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#10 |
Drives: 2023 BRZ
Sure does!
Our last weigh in was at 2658lbs with a 1/4 tank of gas. No driver. The car still has interior, full stereo, stock seats.
#11 |
Drives: 2023 BRZ
Some photos of our Ansix Auto Shop car at Area 27. Check out our site for CANBUS adapters, GoPro mounts, Fire Extinguisher mounts, OIl Baffles and Brake Ducts!
https://ansixauto.com/subaru/ ![]() ![]() ![]()
#12 | |
Drives: 2023 BRZ
#13 |
Drives: 2023 BRZ
We made some very intentional changes to our 2023 Subaru BRZ to minimize the oil pressure drops we've seen previously. Went specifically to a clockwise circuit to test them out.
Vancouver island motorsport circuit, also known as VIMC, has some interesting right handlers. Turn 3, the fast 120kph apex right hander, Turn 4-6, a long 270 degree 10 second long right hander, and T10, a cresting right hander. This video is an onboard lap of the car after the changes that we've made. The fourth gauge on the overlay shows the oil pressure in PSI. You can see the pressure dropping on the right handers but much less significantly than before. We will be uploading a video soon discussing our findings with comparisons before and after the modifications. Subscribe to be notified of when we upload the video.
#14 |
Drives: 2017 BRZ PP, 2004 WRX
Yikes. Seems like nearly every right hander dropped you down near the 40PSI mark. Lots of elevation changes.
| GoPro Mount - Ansix Auto | Ansix Auto | Interior Parts (Incl. Lighting) | 7 | 04-30-2025 12:51 AM |
| 2022+ BRZ/GR86 CANbus Adapter - Ansix Auto | Ansix Auto | Audio/Visual, Electronics, Infotainment, NAV | 11 | 07-04-2023 04:01 PM |
| Element Fire Extinguisher w/ Mount - Ansix Auto | Ansix Auto | Interior Parts (Incl. Lighting) | 17 | 01-17-2023 03:20 PM |
| 2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 1 | 11-28-2022 05:02 PM |
| 2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
