Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 10-17-2022, 02:31 PM   #1
Ansix Auto
FT86Club Official Vendor
Drives: 2023 BRZ
2022+ BRZ/GR86 CANbus Adapter - Ansix Auto
The 2022+ BRZ/GR86 does not have CAN bus connected to the OBD2 port for data logging. For those that want to run data acquisition software for track use, using the old OBD2 protocol is slow and lacking some critical telemetry inputs that are only in the CAN stream.
This wiring harness adapter tees into the CAN network through a module in the passenger side behind the glovebox. This adapter adds a second OBD2 connector in the glovebox specifically for data acquisition. This gives very fast response for vehicle telemetry like engine RPM, Speed, Steering Angle, Brake Pressure, Throttle Position, Coolant Temperature, etc.
This gives you vital insights to maximize your on track performance. Install is simple and will not impact any other systems in the car. Mounting the plug in the glove box is done with one OEM screw + another self tapping screw into the inside of the glovebox for a stealth install. This harness connector ONLY supports CAN bus. For regular OBD2 (such as pulling/clearing codes) use the standard one under the steering column. Recommended to be used with something like OBXLink MX+, RaceCapture, or similar CAN enabled devices.
OBXLink MX+ shown in photos is not included.
https://ansixauto.com/2022-brz-gt86-can-adapter/
Price: $75 USD
Here is a video using RaceChrono app paired with OBXLink MX+ and a Racebox Mini.
Ansix Auto is offline   Reply With Quote
Old 10-18-2022, 06:22 AM   #2
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
You list this as 2022+ so is it safe to assume that this does not work with the 2013-2021 platform?
RongTurnRacing is offline   Reply With Quote
Old 10-18-2022, 07:49 AM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I was wondering this also.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 10-18-2022, 11:31 AM   #4
andys_garage
Drives: 2022 GR86 Premium Track bRed
It plugs into the active sound control plug behind the glovebox - I believe gen 1 had CAN available on the standard OBD port and thus this isn't required.
Also, the margins on this are huge, probably $10-15 in parts here if you're making it yourself.
andys_garage is offline   Reply With Quote
Old 10-18-2022, 01:20 PM   #5
Ansix Auto
Drives: 2023 BRZ
This part is specific to the second gen cars.
The price of this part is not dictated by the parts cost but rather the labor involved in assembly since they’re made my hand.
Old 10-18-2022, 02:29 PM   #6
RongTurnRacing
Thanks for the clarification. It does seem like a quality part and the price does make sense given the rate of production.
Thanks for the info.
Old 01-17-2023, 03:20 PM   #7
Ansix Auto
Drives: 2023 BRZ
We're running a new promotion for the new year!
Buy any GR86 or BRZ product from our site and use the code "knob" for free shift knob!
(Minimum purchase of $75)
Check out our GR86 and BRZ products!
https://ansixauto.com/subaru/
Old 02-20-2023, 05:47 PM   #8
Aroundomaha
Drives: 2022 BRZ
Thanks!
I bought and installed this via Petrel Data since I'm a SoloStorm user. Thank you for taking time to put this together and offering it to the market. To be honest I wanted the data but would not have taken time to create my own adapter, so this option was perfect for me.
Aroundomaha is offline   Reply With Quote
Old 02-21-2023, 06:46 PM   #9
jflogerzi
jflogerzi's Avatar
You don't need an adapter. You can use this exact combo. The First gen can get access to can bus via OBOII port. You will need to configure the data sources. Look into this page
https://github.com/timurrrr/RaceChronoDiyBleDevice
2013 Series 10 FRS #553
Old 03-17-2023, 01:24 PM   #10
Ansix Auto
Drives: 2023 BRZ
We're running a contest for a free shift knob.
We're looking for the HOTTEST hot lap. Post your hot lap videos here. Bonus points if you're using our Canbus adapter to get more telemetry on the video. We're picking a winner at the end of the month. Good luck! We're waiting to see your videos!
Old 07-03-2023, 08:35 PM   #11
jgao20
Drives: 2022 GR86
Hey, I have a Aim Solo can bus wire, how should I connect your connector to the aim solo one?
jgao20 is offline   Reply With Quote
Old 07-04-2023, 04:01 PM   #12
RedReplicant
Drives: None
AIM sells a cable that has an OBD end... but it is the same cable as their flying lead CAN one soldered into an adapter (I went in the reverse direction as you, I desoldered an OBD cable and pinned it to CAN). If you want to save some money and don't want to cut up the Ansix one you can buy a generic OBD end from Amazon and solder your CAN harness to the matching pins.
RedReplicant is offline   Reply With Quote
2022 GR86 or keep my modified 13' frs jiffyjhn GR86 General Topics (2nd Gen 2022+ Toyota 86) 75 02-19-2022 12:59 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 BRZ/GR86 Fuse Tap? Midnightsky Cosmetic Modification (Interior/Exterior/Lighting) 1 01-24-2022 12:05 PM
2022 GR86 MSRP 2k over the BRZ? mangler CANADA 5 12-06-2021 10:51 AM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
