Old 11-18-2022, 01:19 PM   #1
norcalpb
norcalpb's Avatar
Replacement front sway bar bushings - no slit?
Went to go install some new 18mm STi front sway bar bushings on my BRZ and discovered that there is no slit to allow for an easy install! My question is: do I cut a slit myself? Or just power them on over the square bar ends with lots of lube?
The slit on the OEM bushing seems to be on the side:
Old 11-18-2022, 01:27 PM   #2
norcalpb
norcalpb's Avatar
Found my answer and fml lol:
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
RedReplicant (11-18-2022), whataboutbob (11-18-2022), x808drifter (11-19-2022)
Old 11-18-2022, 01:52 PM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
But those are 17mm bushings. Says so right on the side.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
DarkPira7e (11-18-2022)
Old 11-18-2022, 03:37 PM   #4
gpvecchi
gpvecchi's Avatar
I fitted them on mine, no need to boil them, you can just put them in hot water from a tub...
gpvecchi is offline   Reply With Quote
Old 11-18-2022, 08:52 PM   #5
norcalpb
norcalpb's Avatar
I know, strange right! But I'm nearly positive the front bar is 18mm just like on the 2013 BRZ tS. On my beater camry, the rear sway bar bushings also have a 17 on them but are on a 16mm sway bar...
Should've done this but went with the boiling route. Then I grabbed the sway bar like a spear and stabbed the bushing. Went right through, almost prefer this to the split bushings as a solid bushing should be stronger all around?
Old 11-19-2022, 02:52 AM   #6
gpvecchi
gpvecchi's Avatar
The STi front sway bar is the same of all other models, and those are their bushings.
Old 11-19-2022, 08:08 AM   #7
dragoontwo
dragoontwo's Avatar
Subaru seems to under size the rubber bushings by 1mm. If you look on the parts site for the 18mm bar the bushing description says 17mm. The bushing for the 14mm rear bar also says 13.
Any reason you went with the STI bushing instead of poly? Maybe looking for middle ground between that and stock?
Old 11-19-2022, 05:25 PM   #8
norcalpb
norcalpb's Avatar
Ahh that makes sense, probably the most snug that way.
I got rid of poly in the front to reduce the shock of hitting bumps. I noticed that STi does stiff rubber in the front while doing standard rubber in the back, whereas TRD does stiff rubber in the front with poly in the back. If STi and TRD refuse to do poly front, I’m gonna give it a shot to see why if any reason at all.
How do I change the front sway bar bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 03-30-2022 08:47 AM
Replacement/Aftermarket Front Sway Bar Reinforcement Plate Rybot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-04-2018 10:49 PM
Trd sway bar bushings? islandguy69 Issues | Warranty | Recalls / TSB 3 09-30-2017 01:18 PM
TRD Sway Bushings Sweet Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-26-2017 06:34 AM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 05:06 PM
