Old 11-16-2022, 03:19 PM   #1
jiffyjhn
Drives: White FR-S kosei k4r 17x8
E85 FRS getting harder to start in the cold
This is the 3rd year I've run my 2013 FRS on E85.
I've not had much trouble starting the car in the first 2 years. It generally took about 2-3 tries to start when it's cold.
This year as temperature drops, sometimes I need to crank the car like 10-20 times before it would actually start.
Anyone else had this issue? what did you do to fix it? Should I switch back to gas for a while?
My Mods: UEL header, E85 tune from open flash, coilovers and control arms. No mods have been done since switching to E85
jiffyjhn is offline   Reply With Quote
Old 11-16-2022, 05:19 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I usually just do a 50/50 split or even a 25/75 split (e85/gas).
MS, CSCS, TSAC-F, CPT
Old 11-16-2022, 05:32 PM   #3
alphasaur
friendly
Drives: 17' 86
This is the way. A blend will get you majority of the benefit of eth and mitigate most of the issues.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-16-2022, 06:35 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Keep in mind, as the battery ages, it loses its some of its cold cranking amps potentially. With that said, I think Weederr's approach is sound.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 11-16-2022, 09:02 PM   #5
Grady
Grady's Avatar
Who tuned your car for E85? If it is not a custom tune, OF E85 tune is not known for great cold start abilities.
Old 11-16-2022, 11:12 PM   #6
jiffyjhn
Not custom. Off the shelf tune from open flash
Old 11-17-2022, 08:29 AM   #7
Grady
Grady's Avatar
Since it has changed I would try a good battery first as suggested above. From there it it all tune related.
Old 11-17-2022, 11:33 AM   #8
What those guys said.
I am more curious as to where you find E85 in Ontario?
Old 11-17-2022, 03:29 PM   #9
jiffyjhn
Battery is brand new, replaced last month
Old 11-17-2022, 03:29 PM   #10
jiffyjhn
Ahh I'm living in the US now. There are 3 stations within 10 miles of me
Old 11-17-2022, 04:34 PM   #11
Oh that makes sense then. I know a bunch of people here that would love to get it and it just doesn't exist.
Old 11-18-2022, 04:10 AM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Yeah cause a battery has never been DOA before...
Is there something that says the battery is good?
Old 11-18-2022, 10:48 AM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
A test light.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 11-18-2022, 11:09 AM   #14
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
If he can "crank the car like 10-20 times before it would actually start" I would not suspect the battery is the issue..
LRNAD90 is offline   Reply With Quote
Bad cold start 10:1 91 KeepItStock Engine, Exhaust, Transmission 2 04-25-2022 04:33 PM
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
Cold start pop Ash3482 Engine, Exhaust, Transmission 3 03-07-2019 07:39 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
