Old 04-25-2022, 03:51 PM   #1
KeepItStock
Drives: 16FRS hks SC 10:1 91 ecutek
Bad cold start 10:1 91
i got a forged shortblock IAG stage 2 10:1 CR
with a hks v3 SC and some supertech valve springs
Since then my cold starts have been horrible my tuner is taking forever to get back to me so now im giving the forum a try
fuel trims are +9ish until it goes to PI then it drops to +3ish
AFR are good 14.6 it jumps around a lil
my ignition timing is at -4.9 when its bad then when it figures itself out it will jump up to +13 - +14
ive also noticed when it does figure itself out the oil temp is at 100F
i have checked my vacuum lines under the manifold, pcv , and the one that goes to the solenoid
any input is appreciated
KeepItStock is offline   Reply With Quote
Old 04-25-2022, 03:57 PM   #2
norcalpb
norcalpb's Avatar
Hey you may want to try this in the technical section, you are in the classifieds right now.
Old 04-25-2022, 04:33 PM   #3
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
the prez version of subaru has a larger cat AND has a hellish timing retard on start up.
see if you coolant temperature sensor for the ecu is putting out the correct value.
thomasmryan is offline   Reply With Quote
bad fuel trims, cold starts
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
Cold start pop Ash3482 Engine, Exhaust, Transmission 3 03-07-2019 07:39 PM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
