Old 11-05-2022, 06:52 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
2013 FRS Headlight Bulb Options?
So after 9 years one of my low beam bulbs finally burned out. I've done a lot of work on my FRS, but am pretty clueless about headlight options these days. Do I have to use another halogen bulb or can I pop in LED's? Or do LED's require a conversion kit on the 2013? If I can only use halogens again, what's a good long lasting bulb to get?
smg1138 is offline   Reply With Quote
Old 11-06-2022, 08:53 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If you are asking this question just stick to a regular bulb.
LED's require ALOT of research you need to do.
Old 11-06-2022, 10:27 AM   #3
smg1138
smg1138's Avatar
Yeah I've been looking into it and it seems like more trouble than it's worth to me. May just try to get the OEM bulbs from Toyota or Subaru. Does anyone know the part number?
Old 11-06-2022, 04:37 PM   #4
The Sylvania bulbs have always treated me well.
Pick one.
https://www.autozone.com/collision-b...scion/frs/2013
Old 11-16-2022, 08:31 AM   #5
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Pretty sure the right answer is that same as it is for other platforms that came with Halogen Bulbs. Replace the Halogen Bulb with a Halogen bulb, or replace the whole assembly with one designed for an HID or LED bulb. Otherwise the beam pattern is going to be crap, and you are likely to be scattering a lot of light (glare) into oncoming driver's eyes..
Stick with OSRAM or other well known, European manufactured, bulbs for the best quality..
Appears the replacement is an H11. Here are some threads from Candlepower discussing H11 replacement options..
https://www.candlepowerforums.com/th...1-bulb.344034/
https://www.candlepowerforums.com/th...-bulbs.254193/ (higher output but lower life option that requires some very basic modification)
LRNAD90 is offline   Reply With Quote
Old 11-16-2022, 11:39 AM   #6
I have LED low beams in my '13, and have had no issues with pattern, and they were definitely an improvement on projection. The hi-beams are a different story. Since they run as DRLs at half power, you need to either turn off the DRLs, or not replace them.
That said I did replace them with LEDs and it really hasn't been an issue in daylight. You definitely need to remember to turn the lights at dusk though.
Old 11-16-2022, 03:19 PM   #7
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I've been using these GTR Lighting Ultra 2.0 LED low beams for over a year now with no issues. Love the improved visibility over halogens:
https://www.gtrlighting.com/gtr-ligh...-led-bulbs-h11
For halogens, I've had good success with Sylvania, Philips and Hella with various cars and fitments.
If you want to stick with OEM, the Toyota part number is 90981-13075.
NLSP is offline   Reply With Quote
Other options for FRS turn signal bulb base? ChicagoNole Electronics | Audio | NAV | Infotainment 2 01-14-2019 06:59 PM
Trd headlight bulb misterfly Cosmetic Modification (Interior/Exterior/Lighting) 4 05-09-2017 05:09 PM
headlight bulb FR-Sky Cosmetic Modification (Interior/Exterior/Lighting) 3 01-05-2016 03:14 AM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-28-2013 11:00 PM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 02:48 PM
