Old 11-05-2022, 12:22 AM   #1
checkraise36
Drives: 2013 Scion FRS
White Smoke from engine bay
Recently noticed some white smoke from engine bay next to the oil dipstick and under the timing chain.
Initially thought it could be the leaking from the oil dipstick. Took it to the dealership and replaced the oil dipstick o-ring. However, still seeing smokes after replacement. I am starting to wonder if it comes from another place. Has anyone seen similar issues on their cars? Where else could it be leaking oil?
video of smoke:
https://www.youtube.com/shorts/FrJjQDblwvQ
checkraise36 is offline   Reply With Quote
Old 11-05-2022, 01:50 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
You dropped oil straight onto the header. It's going to smoke for a while.
Old 11-05-2022, 11:59 PM   #3
checkraise36
dealership said no active oil leaks and they pressure washed the old residue. But event after all these, I am still seeing smoke after driving back home.
Old 11-10-2022, 08:04 PM   #4
orz
orz's Avatar
Drives: Halo
check the cam plate behind the engine. I read that's prone to oil leaks and can drip onto the overpipe/header. If that was pressure washed then it'll take a few cycles to burn off. If it's not an oil leak then it could be an exhaust leak near the header. It could be a coolant leak near the thermostat or near the tb. Degrease it with full concentration then wash it down. Time to drive it up some ramps and unbolt the dust shield to really see whats going on. What's it smell like? Burnt? sweet? Idk i'm just making stuff up at this point.
orz is offline   Reply With Quote
The Following User Says Thank You to orz For This Useful Post:
humfrz (12-04-2022)
Old 09-04-2024, 08:15 AM   #5
daniloneil8
So, what was the issue and resolution?
I hate when people don't update threads.
daniloneil8 is offline   Reply With Quote
Video. White smoke in engine bay. Car sat for a few weeks. daniloneil8 Engine, Exhaust, Transmission 8 09-09-2024 06:41 PM
White smoke from engine bay ffsrhys Scion FR-S / Toyota 86 GT86 General Forum 20 09-04-2024 08:14 AM
white smoke gt7877 Software Tuning 6 01-11-2020 07:26 AM
White smoke from engine bay after hard driving mfbmike Issues | Warranty | Recalls / TSB 26 07-09-2014 02:45 AM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 06:10 PM
