Drives: 2012 GT86
Hi all, after some spirited running the day before I took my 86 out today and without using high revs a fairly noticable smoke smell started entering the cabin, I checked the engine bay after and quite a lot of white smoke was coming from the bottom of the engine bay.
Here is a video of the issue Any ideas? |
Drives: 2013 frs base
What did it smell like? Hard to tell if it's steam from a coolant leak of smoke from an oil leak. Either way, you will need to pull the bottom cover off and have a look.
Drives: 2012 GT86
quite a strong burning smell
Drives: 2013 Subaru BRZ Sport
Also check under the car, you might have collected a plastic bag somewhere on the road, now touching some hot part of the engine bay.
I have already seen this happen twice, once on my own BRZ. White smoke and burning smell. Or it's a leak indeed. Coolant usually smells slightly sweet. Oil does not. |
Is that oil I see running down the block in the left side of the shot?
Drives: 2012 GT86
I'll have a look underneath later today for debris/leak!
Drives: 2013 FRS
I am detecting a faint burning oil smell when I sit idle in my car.
What's the update on this? |
ProCrastinationConsultant
oil is supposed to be inside the motor, not outside.
did you hit something? run over something? change something? let someone look at something? the possibilities are nearly endless.
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
I just found my cam plate has started leaking, you might wanna check that.
#10 | |
#11 |
not playing cards
#12 |
Sarcastic SOB
I prefer the Starsky and Hutch Gran Torino.
That looks almost like The A Team's van.
#13 | |
#14 |
not playing cards
le sigh
| Tags |
| engine issue, problem, smoke, white smoke |
| Video. White smoke in engine bay. Car sat for a few weeks. | daniloneil8 | Engine, Exhaust, Transmission | 8 | 09-09-2024 06:41 PM |
| white smoke | gt7877 | Software Tuning | 6 | 01-11-2020 07:26 AM |
| White smoke decelerating | azynneo | Engine, Exhaust, Transmission | 6 | 07-23-2016 10:14 AM |
| White smoke from engine bay after hard driving | mfbmike | Issues | Warranty | Recalls / TSB | 26 | 07-09-2014 02:45 AM |
| White smoke in Engine bay | Pinoywhiz | Engine, Exhaust, Transmission | 7 | 04-07-2014 06:10 PM |
