Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-24-2022, 08:33 PM   #1
Vertigyn
Drives: 2022 BRZ 6MT Limited
Lost front camber after T2 install?
Hi everyone - looking for ideas and if anyone else has experienced this issue:
Car with OEM suspension and Raceseng CC plates was at -2.5 camber. We removed the OE pieces and installed the RCE Tarmac 2’s and lowered the car 13mm. We then began to work on the alignment and realized the max camber we could get was -1.
We were expecting equal or more negative camber after installing the T2’s and lowering the car. Very surprised that we can’t even get close to the previous settings we had pre T2.
Any ideas?
Currently looks like I will be going the adjustable lower front control arm to achieve the desired -3 to -3.5 camber.
Vertigyn is offline   Reply With Quote
Old 10-24-2022, 09:59 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You sure the camber plates are installed properly?
Old 10-24-2022, 11:36 PM   #3
Vertigyn
Believe so - they match how they were before and what the instructions state.
Do have a message out to Raceseng to see if they have any thoughts.
Old 10-25-2022, 02:03 AM   #4
mycrors7
mycrors7's Avatar
Drives: zd8 brz
yea there's definitely something fishy going on with the camber plates. they sound like theyre flipped somehow
mycrors7 is offline   Reply With Quote
Old 10-25-2022, 09:39 AM   #5
Vertigyn
CC plates are confirmed to be good with the manufacturer.
Next check is the top spindle bolt to ensure it’s pushed all the way in.
Old 10-25-2022, 11:20 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Weird, you should be able to get more than that with just camber bolts.
Old 10-25-2022, 11:34 AM   #7
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
When you install the strut to hub bolts, make sure you press on the top of the brake rotor as you tighten them down. Something does not sound right with the installation.
Lincoln Logs is offline   Reply With Quote
Old 10-25-2022, 01:42 PM   #8
Racecomp Engineering
Definitely an installation error. You can get much more than that even without camber plates.
Message or call if you need to, send pics.
- Andrew
Old 10-25-2022, 04:39 PM   #9
Vertigyn
Thank you all! RCE responded to my email as well to check the top bolt. That was it…
We are back in business with the ability to get more negative camber.
(The bad installer was me…ooops!).
Thanks again
Old 10-27-2022, 02:27 PM   #10
Tr4ck_day
Drives: 22 BRZ
- Andrew
Current T2 user (and also for my last several cars) and I just gotta say, this is why I love RCE. You guys spend time in your community, and are available to your users in a way that only a small handful of companies can claim to be.
Anyway, just wanted to acknowledge that and appreciate it. 😎🤙
Tr4ck_day is offline   Reply With Quote
Old 10-29-2022, 11:57 AM   #11
Thank you! We really really like what we do and working with cool people that have fun with their cars is a big part of that!
- Andrew
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Positive Camber In Front After Coilover Install bkstarx1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 07-21-2014 01:51 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
