| BRZ Second-Gen (2022+) General Topics General topics for the second-gen BRZ |
Drives: 2022 BRZ 6MT Limited
Lost front camber after T2 install?
Hi everyone - looking for ideas and if anyone else has experienced this issue:
Car with OEM suspension and Raceseng CC plates was at -2.5 camber. We removed the OE pieces and installed the RCE Tarmac 2s and lowered the car 13mm. We then began to work on the alignment and realized the max camber we could get was -1. We were expecting equal or more negative camber after installing the T2s and lowering the car. Very surprised that we cant even get close to the previous settings we had pre T2. Any ideas? Currently looks like I will be going the adjustable lower front control arm to achieve the desired -3 to -3.5 camber. |
#2 |
Drives: Crapcan
You sure the camber plates are installed properly?
#3 |
#4 |
Drives: zd8 brz
yea there's definitely something fishy going on with the camber plates. they sound like theyre flipped somehow
#5 |
CC plates are confirmed to be good with the manufacturer.
Next check is the top spindle bolt to ensure it’s pushed all the way in. |
#6 |
Drives: Crapcan
Weird, you should be able to get more than that with just camber bolts.
#7 |
Drives: #337 2017 Toyota 86
When you install the strut to hub bolts, make sure you press on the top of the brake rotor as you tighten them down. Something does not sound right with the installation.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#8 |
Definitely an installation error. You can get much more than that even without camber plates.
Message or call if you need to, send pics. - Andrew |
#9 |
Thank you all! RCE responded to my email as well to check the top bolt. That was it…
We are back in business with the ability to get more negative camber. (The bad installer was me…ooops!). Thanks again
#10 | |
Drives: 22 BRZ
Anyway, just wanted to acknowledge that and appreciate it. 😎🤙 |
#11 | |
- Andrew |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| Positive Camber In Front After Coilover Install | bkstarx1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 07-21-2014 01:51 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
